Yea, getting some order in the wrokshop is vital- it's all to easy to let things go a bit mad when you've got a few projects on the go!
As far as stock is concerned, it depends what work you intend to do. If you mostly build "The Clones", and work from ready-designed projects, then it is best to order the parts you need for a particular project, but buy the parts in multiples. For example, if you need 3 22pF capacitors, buy 10. It's often actually
cheaper to buy more because of price breaks. This way, you always have a spare on hand, and if you suddenly decide you want to build another one it's much easier.
After a few DIY's you will end up with a nice stock of the most common/useful components.
If you design from scratch, modify current designs or do repairs it's a bit more difficult. You don't always know exactly what you need until it's 2am and you need a certain value capacitor...
I've found the best way to cope here is to buy the component kits available from many suppliers. These are kits of 1000 or so Metal Film 1% resistors with x10 of each value, or 200 electrolytic capacitors. Remember that resistors come in "preferred values". The two most common ranges are the E12 and E24. The range of values is standard in all the "decades". The E24 range is probably the best to go for as it has many of the more useful values for audio work. As a start though, a bag of the E12 series will be helpful.
Have a look in a component suppliers catalogue and see what is available. They often have packs of polyester and ceramic capacitors, and these are handy to have. Just make sure that the voltage ratings of the capacitors are useful to you- some unscrupulous suppliers try to get rid of their less-useful values- e.g. low-voltage electrolytics.
The surplus market can be good for components too. Depending on where you live you may be able to find a mail order place where they get surplus and bankrupt stock. You can often buy a large bag of assorted electrolytic caps for very little outlay. It's then just an evening spent in front of the telly with as many helpers as you can muster ( :grin: ) to help sort them into the correct values.
Here's an example from the people I use in the UK:
Big Bag of Caps
I've got bags like this before, and the price of the bag has been recouped with 2 or 3 high quality capacitors. So have a look around. ANother tip is to invest in some sort of storage system. I like the small plastic drawers which can be removed. The removable ones are good because if you expand the range of values in your stock, it's easy to shuffle all the drawers along to add the new values. The "captive" drawers need to be re-labelled.
Organisation really does make your life easier. I went for years with just boxes of mixed parts, and could never get my hands on specific values when I needed them.
:thumb:
Mark
