Comparison of JFETs for mic applications
It doesn't work to measure uncorrelated noise. Which is why I insist that mickeysoft cannot measure -20.3dB (A) random noise 20Hz-20kHz using two microphones with 5.5dB(A) self noise.r
As someone else mentioned, averaging works only for separating non-correlated noise from correlated signal.
When both are random, it just doesn't work.
I think some terms are confused here, I will try to clarify them a little, the way I see it with my limited knowledge and sometimes lack of accurate information.
The MS anechoic room measurement was made by experts from the B&K company, the result was recognized as a Guinness record. I see no point in denying the accuracy and relevance of this measurement.
When it says -20dB(A) it means exactly that, 20dB lower signal than 20uPa, measured using the A type curve (the A type curve is determined in the frequency range from 20Hz to 20kHz, and cannot be applied to a non-wideband signal, e.g. a 1/3 octave filtered signal).
For example, the noise of the BK 4179 cartridge is declared -5.5dB(A), with the amplifier it is -2.5dB(A), while for 1/3 octave at 1kHz this noise drops to -16dB, and with additional band reduction it can be reduced to -34dB(re 20uPa).
When measuring with two microphones, the uncorrelated noise is the Brownian noise generated on each microphone membrane. The second noise that we want to measure is actually the signal that has penetrated our anechoic room. It is correlated in both microphones (that is why the microphone membranes are placed next to each other). So, we have two different types of noise.
Finally, the coherent power measurement technique allows us to measure the values of noise which can be lower than the value of the total noise produced by an individual microphone. So, it is possible to use this technique using microphones with 5.5dB(A) noise to measure the presence of a signal (in this case, it is the unwanted noise that has entered the room) which is lower than that value.
What I said, no?
Yes, but by doing so we reject ALL random noise, including Brownian motion noise, so we cannot measure -20.3dB Brownian motion noise this way.
Theory suggests that for 20Hz to 20kHz bandwidth the Brownian motion noise on the diaphragm is a smidgen above "0dB".
Of course, we can measure -20.3dB(A) Brownian motion noise, we just need to pick a bandwidth of 20Hz -200Hz, apply A-weighting.
To figure the theoretical A weighted Brownian motion noise under these conditions is left as exercise to the reader. It's lower than -20.3dB (A) incidentally.
Thor
What was measured here was not Brownian noise, but a signal (you can call it noise if you want) that penetrated the anechoic room. And its value is the famous -20dBA.
Eliminating non-film capacitors so only very high grade coupling capacitors are used .... balanced supply currents, that is generally expected for microphones.
... loadsa stuff some good but some dodgy ...
, for transformer coupled inputs the "simple P48" will magnetise the core permanently, degrading performance and causing the transformer in effect to bd destroyed, if using a DC coupled inputs, the DC difference will stop the circuit from working.
Some dodgy stuff here (along with some good stuff of course as expected from Thor :) )
I'll just answer the stuff about transformer input preamps. Various MicBuilders have tested SimpleP48 with these and these are known to be OK long term with Lundahls, Sowters & Jensens. Lesser brands might have problems. And several $$$ mikes also have this sin with even MORE EVIL unbalanced currents. It's all in SimpleP48.pdf
I'm not sure Thor is of the vintage that unnerstans transformers in preamp design so he is forgiven for doubting Great Guru Baxandall et al.
For his other criticisms, you can build a rather good omni with SimpleP48 for less than $10, probably less, with stuff in your junk box in less than an hour, and see (hear) for yourself.
Having been responsible for probably the most complex mike of the 20th century, these days, I look with a jaundiced eye at any complexity that doesn't give me more practical advantages compared to SimpleP48
The "high grade capacitors" and other stuff comes under "my stuff is hand carved from Unobtainium & Solid BS by Virgins"; really important for any commercial maker. But you can claim this without putting any s**t into your product as long as the user is ... Shut up! Just SHUT UP!!!
This is what I find dodgy. If the noise is correlated in both microphones, would it be also correlated between different 'samples' that you are averaging.
Unless of course Microsoft, in their infinite wisdom built their anechoic on top of a generator which was the main 'external' noise source. Such a noise can, with suitable digital juju, be suitably aligned such that subsequent samples to be averaged, build up.
They could have used a zillion 4955s (?) and done a 'single' sample ... but then this begs the question of how a zillion 'closely spaced' mikes will pick up a 'correlated(??)' random signal A page or two of obfuscating maths re spaced mikes in a 'diffuse' soundfield deleted.
Gotta watch the video again to see if any old Naerum B&K people appear that I know from da previous Millenium
Duu.uh! Only 2 x 4955s. No Danish B&K engineers. Indian engineers must be as s**t as Thor's Chinese engineers.
And I can hear an annoying Microsoft bell sound even at their -20.6dBA :eek:
Unless specified for DC current, the permanent magnetisation of the core will happen, including reduced primary inductance and increased distortion.
No, all of them, unless explicitly designed to handle unbalanced DC.
I am sure. The circuit floated around for decades.
I understand audio transformer design itself quite well, thank you.
I don't really need this. What if I want to build a good LDC with externally biased capsule? Which is what my designs are for.
The objective performance difference is quite stark.
Thor
That is the point.
External noise (say the subway passing under Kingsway Hall or the distant FLAK on the first hifi stereo tape recordings of music in Berlin in 1943) is both from a distant source and not random.
Both microphones react to it equally.
Random electronic noise and Brownian motion noise from the microphones is not correlated but random.
On the rule that equal levels of random noise adds 3dB while two correlated signals add 6dB, we gain 3dB SNR by using two microphones or two samples.
Every time we double the number of microphones or of distinct individual samples we gain another 3dB.
With 2.5dB(A) effective self noise we only need to average 256 Samples with (say) 64k sampls size to get below -20.3dB(A).
Or 512 individual microphones will do the same.
Thor
I would think not. Recording simultaneously with two microphones will record any ambient sound in phase. Recording at different times will record different sounds, or if they're steady sounds, record them at randomly different phases.
So, for example, if you have an ambient 60 cycle hum, recording 512 versions of it randomly staggered in time will tend to make it mostly cancel out.
And any uncorrelated, one-shot noises would be averaged way, way down with recordings where that one shot doesn't happen at the same time.
Actually, ALL transformers are victims of magnetization, not only permanent but also that generated by the actual circulation of current through the windings (H field).
A xfmr "specified for DC current" is just one the designer defined an acceptable deterioration of performance. A transformer "specified for DC current" by manufacturer X maybe unacceptable by manufacturer Y or client Z. It's all a matter of expectations.
No common xfmr is actually 100% ungapped. And no xfmr "specified for DC current" is actually immune to the effects of DC.
Yes, but to apply significant DC current to a Transformer with Mu-Metal cores not explicitly designed to operate thusly causes permanent, practically irrecoverable deterioration of performance.
Not quite. It is one that is DESIGNED EXPLICITLY to withstand the specified DC current while the deterioration of performance is within the specified paramebters.
A transformer specified for x mA DC should provide rated performance at this level of DC, so it is not a question of expectation, but of reading the datasheet, presuming there is one that is adequate.
In 2024 many are made on gapless amorphous/nanocrystalline toroid cores. Nagra uses these, for example.
Any transformer designed explicitly to handle a specified level DC will perform as designed with this level of DC and performance will deteriorate at greater levels of DC.
If it is explicitly designed to handle 0.00 mA than applying ANY DC will degrade performance.
Perhaps the degradation and the permanent degradation of performance is acceptable, but it needs to be warned against.
Finally, as I am critiquing the SimpleP48 circuit for being too simple, it does behoves me to show an alternative that addresses somebunall of the grosser shortcomings.
Both this and the original circuit share the same shortcomings. Absolutely awful HD approaching 10% at 124dB SPL (assuming a -40dB sensitivity Capsule), poor cable capacitance handling, really, there is nothing whatsoever to recommend either the original 2 component circuit or this one when we have better options.
Yes, either version will work and some sound will come out. Which may be enough for some.
For the rest...
The 10nF and smaller Capacitors should be C0G (in 0603 to fit the BM-800 PCB which uses lower grades) or film. For the 100n C0G are preferred as well, but X7R will probably not be the end of the world. 1uF need to be X7R.
The BSS84 need to have matched threshold voltages. The ones I had so far from a reel all matched so well, no extra action was needed.
The bias chain (given 1% resistors) will have > 35dB suppression of Audio across all frequencies, the lowpass filter effect adds ~ -60dB @ 20Hz, so any audio will be attenuated by at least 95dB @ 20Hz, with a 60dB/decade slope.
As shown here, we have 40V 35V bias, not 60V, which will take 3.5dB 4.7dB of the sensitivity, so a -34dB/pa @ 60V sensitive LDC capsule will produce -37.5dB/pa -38.7dB/pa or 11.7mV/94dB to convert into modern money. Using P68 instead of P48 and adjusting R16 (switchable?) would recover this sensitivity, but it is unlikely to improve SNR materially.
4Hz-100kHz -3dB with an option for a HF roll-off (increase C2) to limit how bright mic's are.
Predicted is an unweighted 14dB 20dB self noise 20Hz-20kHz, so perhaps 10dB(A) 16dB(A) without accounting for Brownian Motion Noise and acoustic resistances etc. I would say "low enough for music recording" but not phantastically low. About 30dB 36dB worse than -20.3dB(A).
With a 2.2k Mic Pre input load we can handle +35dB/pa or 129dB at ~ 0.2% THD +40dB/pa or 134dB at < 0.5% THD (H3 dominates) with a -34dB/pa @ 60V bias capsule.
Higher loads allow more SPL.
As mentioned before, this will easily be able to be realised on the BM-800 PCB with a few cut's & jumps.
Add the favoured AliExpress K47 or whatever capsule plus saddle, a true studio grade recording LDC is done.
Anway, enough from me.
Thor
I am not aware of Mu-Metyal that can't be demagnetized.
That's exactly what I said. Specified parameters are arbitrary. Deterioration accepeted by designer may be inacceptable for another individual.
Many for you may be very few for others. They are still exceptions in products available to DIYers.
Acceptable is the word.
There is no absolute zero current like there is no absolute evil or absolute good. Everything is variable, with more or less abruptness.
By the average DIY enthusiast with the tools he has. I work with transformer makers who demag their transformers before shipping. So I do know how it's done.
Maybe you describe the process for those who are ignorant?
Then the initial stated parameters would also be unacceptable, as they would/should be quoted at rated DC. So we are back to kindly read the datasheet.
So you agree your previous statement was not correct?
This statement:
Clearly now there are many that are. Look for the watchwords "amorphous" and "nanocrystalline".
Again, I will state that this is a design issue.
If I define a transformer to have a given frequency response, loss and distortion behaviour in a given circuit but I specify "0mA" DC in one case and "1mA DC" in the other, I will get different transformers.
We design transformers for a set of performance requirements. The Amount of DC to be handled is part of the specification and alters the design of the transformer.
Do you really want to argue that this is not the case?
Thor
E.G Lundahl have less than 10% of their references in amorphous, Cinemag, Haufe, Sowter have none.
I don't want to argue, I leave that to you.
One can design a transformer that works with either 0mA or XmA. It all depends how much deviation from arbitrary design goals is allowed (again an arbitrary decision).
Design decisions hopefully are not arbitrary.
We have gone full circle.
You say any transformer will work with any amount of DC that doesn't cause thermal damage.
You just have to accept gross performance deterioration.
I say that I select, specify or design a transformer for a specific set of results, usually the minimum requirements, as over designing costs extra, in audio transformers often a lot.
So performance deterioration means less performance than I required to make a functional product.
To me this deterioration means the product is "broken", just as you would state that a plane that doesn't perform as required and designed is broken and needs fixing. According to your position, no matter how bad the planes condition, if it moves at all and can take of and land somehow it's ok.
I will have to agree to disagree fundamentally with your position, not even specifically about transformers, but on the general concept that if performance of something is degraded beyond minimum design requirements the device is just fine and functional.
There is a reason why I only fly on Airbus and Embraer planes and rebook it's a Boeing or an old Soviet deathtrap. Both post McDonnell Douglas merger Boeing and the Soviets build planes on that sort of philosophy you suggest for audio transformers.
So, audio transformers do not kill if they perform subpar, the way planes do, but they are still broken.
So, how do you demagg a permanently magnetised mu metal core in an audio transformer?
Thor
Yes they are, because they are based on performance expectation. Someone who's satisfied with e.g. 1% THD at 20Hz will specify and design accordingly. Another who expects 0.1% will design and specify differently. Same for frequency response an dmany other factors.
I don't think I ever said that. You must confuse me for someone else.
Any design induces performance deterioration. The tolerable amount of which is arbitrary.
Deterioration of performance of a xfmr vs. DC current is not a Go/NoGo, it's progressive, and how much one tolerates is a choice, arbitrary at that.
It's your choice: how much the final design achieves your goal is left to you.
No. Performance deterioration is inherent to the essence of products. Only unreal products are perfect.
No real product is perfect, so, according to this, no real product should be launched.
I don't know where you got this impression.
You must have dreamt it.
We can agree on that. Although I had to fly an Iliouchine one day, because it was the only flight available.
You are utterly mistaken about "my philosophy". I just mentioned that no part is perfect, and how usable it is is up to the designer that conceives it and the persons who use it.
Submit it to a fading low-frequency sinewave. I used to do that with a simple potentiometer, but today I can use a tone generated by a DAW.
I believe this method is documented in a Studer paper.
Peace Abbey. No point arguing with Thor who knows more about transformer design than GG Baxandall. :eek:
Let's make use of his genius instead. :)
Finally, as I am critiquing the SimpleP48 circuit for being too simple, it does behoves me to show an alternative that addresses somebunall of the grosser shortcomings. View attachment 142934
Thor, I think you might have made an error in the above circuit but I point this out only with fear & trepidation ???
For the rest...
Thor, as you have obviously built this mythical beast, did you do any measurements of this "objective performance materially better than most Chinese microphones available" ? :eek:
Just sensitivity, response and preferably noise curves like the B&K one posted by moamp or pages 10 & 11 of my Zephyr.doc
It would be nice to compare your Supa Dupa variant with MUCH simpler Schoeps variants like the one in Zephyr.doc
It would be good if you have the capacitance(s) of the Ali capsule you used but we can guess if this is inconvenient.
THD with level will be nice but we know this is difficult to do properly. Of course you could do 'THD with level' just electrically with a COG cap in series with your oscillator :)
I think you may be right. The mic to source, not ground. I just quickly hacked up an existing schematic of something else. Lucky I saved this...
The results for distortion are Wired Al Yankovitch connected correctly. And I thought the Sum Ting Wong version was already Michael Jackson.
I measured using the usual tools. Lacking a sufficiently quiet anechoic chamber and a sufficiently linear sound source to characterise the whole microphone (I'm few billion short of a Mickesoft White Elephant Anechoic Chamber), I only unit tested the electronics.
Capsules vary, mostly K47, K67 and C-12 knockoffs. Each matched to a BM-X00 body with approximately the matching head basket stripped to one layer and the body spray-repainted in the right hammertone.
Most are around 65pF, I measured them, I also measured the completed mic against a calibrated ECM-8000 with a speaker to get an idea of FR.
As I had no interest in publishing, I didn't collate the tests in detail. Some printous are probably with everything in China, I really need to find the time to go over and get my stuff. That or go to the beach night market for a brew and BBQ.
ITS NOT "SUPA DUPA".
It is actually quite verbatim, simple and actually utterly primitive.
It was based on the BM-800 (etc) SMD PCB shown earlier. So the limitation was it had to reuse the PCB as much as possible and use parts that fit.
One key change is the PNP transistors to a very low noise P-Channel MOSFET, which literary drops on the PCB and changed resistor values and an added gate to source resistor.
Other changes were also done mostly by just swapping parts. Q5 position for MMBF4393 (SMD J113 - needs bodging in, doesn't fit PCB footprint) for the cascode.
Fix the noisy regulator.
Add the bias RC chain.
All very simple.
Q1 was completely removed from the PCB (and replaced by 2SK660) and with final bias RC components moved to the capsule, where it belongs.
So the connection to the gate is really short.
Now 4 wires from head to PCB, but that's a non-issue and they are pretty low impedance lines.
AP2? And yes. Actually polystyrene cap, as I kept them for those jobs that need somehow capacitors added for tests in a range of values.
This was not a serious design, just a quick and dirty hack because I needed some Mic's and was disappointed with the common ones (reimported after being made in China and sold expensive in the west), to point where I figured "I can do better than THAT on a rainy Sunday Afternoon".
Thor
Correct. But "fading low frequency sinewaves" covers a lot of ground.
Do you have a suggestion of the levels needed for a typical microphone input transformer? Is the level needed frequency dependent?
Let's say I use 50Hz and -20dBu, this will be good? Or do I need to use 5Hz and +20dBu?
Thor
