Or did you mean Jensen? See chapter 4.2 here.Submit it to a fading low-frequency sinewave. I used to do that with a simple potentiometer, but today I can use a tone generated by a DAW.
I believe this method is documented in a Studer paper.
Jan
Or did you mean Jensen? See chapter 4.2 here .
hi,
Thanks for this Thor.For the rest...
Predicted is an unweighted14dB20dB self noise 20Hz-20kHz, so perhaps10dB(A)16dB(A) without accounting for Brownian Motion Noise and acoustic resistances etc. I would say "low enough for music recording" but not phantastically low.
It's unfortunate your starting point is a particularly bad version of BM800.
Some of its sins have passed into your circuit which would be noisier than Zephyr's version of the Schoeps from above 1kHz culminating in more than 11dB extra in the aurally important 4kHz and above.
This BM800 circuit responds well to Muntzing for better performance. Your regulator improvements are worthwhile but replacing it entirely with cheapo resistors & capacitors gives even better performance ...
unless you need the mike to work in P24 & P12 situations.
There is at least 9.2dB S/N improvement available on top of this.
I would keep the HP filter.
I hesitate to point out SimpleP48 has even better noise ...
This Mic circuit I show is P48 only.
SimpleP48 has about a 1dB noise advantage over a properly designed classic Schoeps mike in the cases where the 'electronic' noise is sorta verging on being prominent. It has MUCH more advantage over poor implementations like BM800.Does it now. Just how much better, as we are doing a contest?
I find the TINA simulator quite close to reality, I'll run the numbers.
Alas, SimpleP48 only works with electretsLet's agree on the C-12 capsule. I'll pull the tech data.
2SK660 used for both? How do we bias the capsule in the SimpleP48 ?
Can TINA produce a noise spectrum curve like the one on page 10 of Zephyr.doc ?Noise, THD @ 94, 104, 114, 124 and 134dB if it still makes sense. Would you like something different.
This is just to get a 'sensitivity' figure. We could use -66dBV/Pa which would be within 2.5dB of Zephyr's Schoeps variant with the ISK 34mm capsule.Can we use a hypothetical capsule with the same capacitance as CK12 and assume Vp 60V ?
Thor, who's 2sk660 SPICE model are we using?
I'm worried about the 'reverse diode' across G-S.
Guru Scott Wurcer points out the reverse current at low voltage should be about 1pA.
No maker specifies anything that low as it's very temperature & voltage dependent. But that's what it needs to be.
And forgive my asking but does TINA simulate resistor noise properly?
I want the 'capsule + FET' side to be LN enough to clearly see the differences in the rest of the electronics ... as is the case with Zephyr's mike.
This would be useful to all and sundry ... as would THD at different spls for this 'hypothetical' capsule with SimpleP48RCA.
Much better than a "mine is bigger than yours!" shootoutMuch better use of your time and effort too for which I'm sure everyone here will be grateful.
Does anyone have a pukka Windows XP install disc they could send to a beach bum in Cooktown, Oz?
Hi Thor, I'm sorry to bother you,Let's stick with something real.
I used these capsules in a front address mic:
I just found this on AliExpress: US $28.00 | 2PCS 26mm Diaphragm Condenser MIC Capsule Microphone Cartridge Electret Cardioid https://a.aliexpress.com/_okEySpP
Sensitivity: -35dBV/PA (+/-2dB)
Capacity: 42pF +/- 4pf
Let's work with design center values.
These are reasonably close based on my experience.
They are overall also not that bad, not LDC, but decent MDC... I literally used the same circuit minus bias but on a narrow, long PCB.
It would actually be worthwhile for someone else ting a decent basic mic to use this capsule.
The mic body I used was a copy of the one they use on "Voice of Scheena".
Lots of Mongolian Throatsinging I expect. I never watch Chinese Children's Television (CCTV), so I wouldn't know.
Nice suspension integrated. Nice cast body.
Result reminded me a lot of the EV BK-1 which I loved in the 80's as vocal mic's.
Thor
Corrected.Hi Thor, I'm sorry to bother you,
the AliExp link doesn't work for me
Okay Mr. Thor!
Thanks!![]()
Alas. I need an actual Windows XP machine. Machines that have the correct drivers for XP are all at least 10 yrs old.You can get winXP for virtualbox - e.g. https://archive.org/details/xp51_20191108
It's complicated as all my serious software was written in DOS days.
[...] Personally I find TINA more intuitive and user friendly than LT-Spice (aka switchercad). TINA comes more from an educational angle, while switchercad was an LT internal tool for switching supplies. Nowadays results seem close enough to identical.
https://www.ti.com/tool/TINA-TI
Free download here. I'm happy to send you some SIM files for simple circuits. that you can load and run to get your feet wet. [...]
