Comparison of JFETs for mic applications
I've always been curious about this method of biasing the 2SK660; it's from the Audio Technica AT8533 power module; so different from the way FETs are usually biased in microphones.
The PNP transistor acts in effect as a Zener Diode (or Vbe multiplier), which produces a fairly constant emitter voltage.
The emitter is supplied from a current source (CRD) from the centertap of the output transformer.
The 1k load for the Mic capsule FET comes from the PNP emitter. It seems to be a follower, with the Diode in the acting as "floating" powersupply of ~ 0.6V for the J-FET, that's DEEP in the triode region.
As the signal out of the J-Fet goes via a cap to the base of the PNP the PNP transistor in effect bootstrap's the 1k Resistor.
Overall capacitances are well cancelled, it's a fairly linear follower into a transformer.
It looks complex, but fundamentally it's simple.
I'm not surprised it sounds good, if we measure this circuit, I expect even order HD dominant with very low order of HD, plus likely a fair bit of pink noise.
Thor
Thor
Thnaks
Did look like a bit of a bootstrap to me. Wonder why this type of bias isn't seen more often.
This is the Shure version (don't know for what FET):
  • SM90:91.png
    1.4 MB
Most people get a headache looking at this.
The J-Fet operated at extremely low voltage.
There seem to be many thermally dependent voltages.
A lot goes against "received wisdom".
Peeps just "don't get it"!
Thor
"fast and bulbous
(Hey, do it again) I love that, I love those words
Fast and bulbous, that's right, the mascara snake
Fast and bulbous
Bulbous, also tapered (yeah but you gotta wait until I say it)
Also, a tin teardrop (oh, christ)
(Again, beginning)
Fast and bulbous, also a tin teardrop
Bulbous, also tapered, that's right
A squid eating dough in a Polyethylene bag
Is fast and bulbous, got me?"
