AdamFrisen
I found this from former technical director of Neumann in US:
from: https://repforums.prosoundweb.com/index.php?topic=36194.0
That's a very interesting post, however there is an element of confusion, which has been noted by Klaud Heyne.I found this from former technical director of Neumann in US:
Re. Abbey's point - yes, that's confusing. The capsule generated THD will go down, but that's not what is being measured when applying signal to the calibration input.
It seems (correct me if I'm wrong) many prefer charge amp types over unloaded capsules.So do we want more of that "vintage THD", or less, or the same exact amount, or maybe focus on harmonic profile throughout the spectrum instead of TOTAL harmonic distortion, mostly expressed as a meaningless figure at 1Khz?
Device | Ein (dBV) |
J113 | -123.7 |
2N3819 | -123.0 |
BF256B | -122.2 |
J305 | -122.8 |
2SK117 | -118.2 |
2SK30A | -121.4 |
Device | Id (mA) | Vgs (V) | Rbias (calculated) |
2SK246-BL | 0.35 | -3.15 | 9.0K |
2SK369-V | 0.21 | -0.57 | 2.7K |
2SK373-GR | 0.35 | -0.92 | 2.6K |
2SK709-V | 0.30 | -6.0 | 20K |
Device | R4 | Vds (V) | Gain 1nF (dB) | THD 1nF (%, 1KHz, 100mV) | Gain 68pF | THD 68pF (%, 1KHz, 100mV) | Ein, 1nF | Ein, 68pF |
2SK246-BL | 68K | 1 | -0.21 | 0.0026 | -0.29 | 0.0029 | -124.0 | -120.8 |
2SK369-V | 33K | 1.3 | -0.16 | 0.0015 | -0.25 | 0.0023 | -127.6 | -122.4 |
2SK373-GR | 33K | 1.37 | -0.18 | 0.0021 | -0.25 | 0.0023 | -122.2 | -119.4 |
2SK709-V | 47K | 1.9 | -0.2 | 0.002 | -0.27 | 0.0021 | -124.2 | -121.3 |
2SK3557 | 33K | 1.9 | -0.19 | 0.0024 | -0.24 | 0.0026 | -127.5 | -122.4 |
BF256B | 47K | 1.2 | -0.17 | 0.0014 | -0.22 | 0.0016 | -123.2 | -121.4 |
Hi Voyager10Noise measurements
These are using MicUlli's circuit (post #38), with a 4.7uF bootstrap cap (post #39). I've also included BF256B and 2SK3557 measurements, which weren't previously included.
As before, measurements were made with 1nF and 68pF source capacitances.
Device R4 Vds (V) Gain 1nF (dB) THD 1nF
(%, 1KHz, 100mV)Gain 68pF THD 68pF (%, 1KHz, 100mV) Ein, 1nF Ein, 68pF 2SK246-BL 68K 1 -0.21 0.0026 -0.29 0.0029 -124.0 -120.82SK369-V 33K 1.3 -0.16 0.0015 -0.25 0.0023 -127.6 -122.42SK373-GR 33K 1.37 -0.18 0.0021 -0.25 0.0023 -122.2 -119.42SK709-V 47K 1.9 -0.2 0.002 -0.27 0.0021 -124.2 -121.32SK3557 33K 1.9 -0.19 0.0024 -0.24 0.0026 -127.5 -122.4BF256B 47K 1.2 -0.17 0.0014 -0.22 0.0016 -123.2 -121.4
The plots below include the 2SK209 figures, which is amongst the best previously measured, for comparison.
View attachment 142407View attachment 142408
How variable do we think these devices are unit-to-unit? Are you testing just one of each, or if not, how many until you've established "average" behavior of each device? In my experience, most FETs vary widely.
It seems that 2SK170 is one of the most counterfeited items.The outliers I've had are 2SK170s, where a batch I had from eBay had 2-3dB worse noise than others (recovered from a dismantled mic PCB).
I only buy from trusted sources like Mouser and Digikey. I've bought several "original" (yeah, sure, haha) audio ICs on Aliexpress. All of them were counterfeits. Don't try to save a few pennies on JFETs when you're spending hundreds of dollars/euros on capsules...The outliers I've had are 2SK170s, where a batch I had from eBay had 2-3dB worse noise than others (recovered from a dismantled mic PCB).
Well, it doesn't help that 2SK170 has been discontinued for a while...
