Hi Samuel,
Thanks for writing back. I finished the circuit straight away using the OPA604 design.
I did not know what you meant about "DC issues" - did you mean offset voltage or bias current?
Anyway, I have not actually got the circuit to work yet. I thought I would test it with some different opamps first (the OPA604s cost me £5). So, I decided to plug in two spare OPA2228 opamps - very stupid - I forgot that they are dual opamps - not single.
I am using a 2 X 9v battery supply to provide +9v and -9v and polarised capacitors (I will get bipolar soon). After plugging the OPA2228 opamps in, they got very hot, so I pulled them out.
I thought I should check the voltages on the IC socket pins with no opamps connected.
I get -9v on my -supply pin which is good. But, my +supply pin reads 4v which is increasing slowly (4.1, 4.2, 4.3, etc.) - I think this is because I have drawn so much current from the batteries and they are recovering.
My inverting input (-) and my output both read -0.2v. Is this ok?
I don't want to plug in my new OPA604 opamps and burn them - should I plug in some other cheap opamps first to test it? I could buy some cheap ones.
The OPA627s are £15 each! That's a lot of money!
What is C1 for anyway? Why would an OPA627 not need C1?
Thanks for your help!
Roddy
Roddy
