Michael Tibes
psb_87 said:...I spoke to Allen & Heath directly on the matter and they actually used to offer a balancing kit for the console. Looks like a really simple and inexpensive circuit:
http://www.allen-heath.com/media/EBOS-BALANCED-OUTPUT.pdf
Am I overlooking it or is this not even cross-coupled, so that it acts 'Transformer-like'? I believe if one of the outputs gets grounded (connected to an unbalanced input), it will be shorted and therefore distort. The solution with the That (and other manufacturers) chips doesn't do that, there will certainly be papers at thatcorp explaining the matter. If you absolutely want to balance it, I'd use one of the chips dedicated to the task, they are pretty good. Though in my opinion the only advantage of balancing the outputs vs impedance balancing is a roughly 6 dB higher clipping point, given the same powersupply voltages. I'd always go with impedance balancing unless the headroom is needed. GML gear uses it and as far as I remember the SSL 4/6k worked the same way on the inserts.
Michael
