keefaz said:Signal goes from IC4 out (impedance like 0R), then goes through R87 22R to direct out.
So output impedance is 22 + 0 = 22 ohms.
Remove the output jack socket ring / sleeve connection, solder a 22 R resistor between ring and sleeve, then you have impedance balanced out
Thank-you very much, a perfect answer.
