Dmichel123
We recently purchased a late '50s/early '60s custom-built tube console from eBay. It has 5 Hi-Z mic inputs with a single 5879 per channel. The "program" line amp consists of a shared plate 12AU7 as a mixer (one half for mic mix bus, other half for line/TT/tape/radio bus), and another 12AU7 as a gain stage and cathode follower for the output.
I have started work on customizing the console for our needs here in the studio. I've rounded up some input transformers for the mic pres and likely have a suitable transformer for the output (600:600?) around here somewhere. I have removed the second row of knobs (TT/tape/radio/etc. inputs) and will make these aux sends for the mic pres. Each aux send pot will get it's signal straight from each channel volume pot, into aux bus, straight to aux send jack. The aux return will come in at the 12AU7 mixer.
I am working on drawing a schematic for the full console. For now, I have drawn up the preamp circuit with as-built values, plus aux send pot and input transformer. Originally, the pres fed into the volume pot at the wiper. I've moved that to the top and added a 250k resistor after the wipers into the bus feeding the 12AU7 mixer. I will add 100k Rs before the AUX bus.
Any tips or corrections are greatly appreciated! If you see any changes that could improve the pre circuit, let me know!!
Danny
Danny
