Volker,
thanks, I'll try some different transformers for sure, but understanding why one transformer works better than others is really my question. here's why .....
Example : take the different tx's below having qualifying specs for input usage.
A20 1:1 (500:500) max level +15dbm
A22 1:1 (500:500) max level +30dbm
Altec 15335A 1:1 (15K:15K)
based off specs above could you actually make a case that one is better than the other without a sound test.
Even if all these are 1:1, is the 500:500 loading compared to the 15k:15K going to make a difference. Based on what gets plugged into it in the signal chain such as a guitar or a mic for example, will the two react
relatively the same , if so why ? if not why ? It seems to me that there would be a difference due to impedance in the winding between the two. What effect would 600 have over a 15K or a 10K for that matter. What would I expect to hear or not hear if I were just basing my decision solely on transformer specs ? ( complicated enough )
I'm trying to understand the specifics in aquiring a optimal transformer. In many cases , buying a transformer on specs does'nt allow for a sound test until later. So, knowing more about specs might decrease the uncertainties in getting the wrong iron and increase the success for getting a transformer that will be correct. I always feel transformer selection is like gambling, and I want to take the element of chance out of it as much as possible. I've always rely on proven results because who can afford to keep enough transformers around to ensure thru sound testing , you have the right one for the job.
In many instances, having the original iron for a project involves having the vintage iron. The cost of vintage iron has made it popular to go to alternatives due to cost. In this case I always ask the question - what alternative should I use. Well, I usually call the manufacturer and get the suggested alternative, but what if I find something unusual and I want to use it in a project, what then. Here is where knowing specs becomes important and here is where confusion begins.
Basically, When I look at transformer specs, I want to be able to make a experienced decision without wasting to much time and money.
Am I making any sense ?
