Continuing my efforts with this most interesting compressor unit ...
I subbed in a genween LM350T in place of ebay fake and voila, all good wrt heaters and such.
Changed a couple of dropping resistors in the low voltage circuit with some higher power ones too.
After some quick checks, I confirmed my previous performance figures - unity gain noise floor at typical setting gives me a noise floor of around -74dBu (an averaged figure as reported by my RTAS 20Hz to 50KHz) vs a loopback noise floor of -80dBu for my Motu 828MkII test setup.
50Hz component < -100dBu, 100Hz component < -85dBu
The Motu is calibrated to the limit of my capability for the dBu standard with 600R load and absolute voltages. I use a combination of my CRO, DMM and some high quality iso transformers for this task.
Freq response is -1dB at 20Hz and -1.8 dB at 24KHz and very flat. Square waves are good and clean. Distortion is quite low.
Variation fro chnA to chnB is around 0.3dB maximum across the available makeup gain range.
All in all the no Gain Reduction performance is very nice indeed.
So, I turned my attention to the sidechain. First I measured the dc levels and then the ac levels of the various bits of the sidechain amp.
Very nice - both channels virtually identical in ac performance. In dc, currents were less than a mA or so different across the channels with 2V or so max difference in hv.
All very good. I noted the gain stage of the sidechain has a bias of 3.75Vdc and a current of 5mA more or less. Gain was x8.2
The cathode of the sidechain cathode follower sits at 140Vdc or so and a current of 6.3mA or so. Gain was 0.92
Total sidechain current is around 11.3mA. Overall gain was around x7.5
So I would expect around 7Vpp in and 56Vpp out of the gain stage without clipping and a cf swing of 165Vpp or so max to feed the dc coupled vactrol.
I measured something like 86Vpp out of the gain stage before visible clipping/rounding. The CF is of course capable of more than that.
Having established the sidechain dc and ac were working well and virtually identical across the channels with no Gain Reduction occuring, I set about to look at the vactrol circuit including the mods I started up with - basically a 4 position switch with an on/off inline with it, the whole thing across the single vactrol + and - terminals.
When the on/off switch is open, the 'response' circuit I did is not in-circuit. There is virtually no GR because the stock vactrol arrangement requires a ton of level to get it to squeeze.
When the on/off switch is closed, the 'response' circuit is in parallel ith the vactrol and has an effect.
I used 'soft' (100K resistor), 'hard1', (parallel blue led), 'hard 2' (1K resistor), 'hard3' (anti parallel red led).
The positions all seemed to work and all seems to be fine. Now to look closer at the curves.
For my tests, I decided on an input maximum which result in the sidechain signal at it's more or less unclipped max - 86Vdc. I reason there is no need to run a distorted sidechain before the vactrol.
I have a useful range on my motu RTAS of 12dBu max output, so I set that as my maximum level into the doac. I then adjusted the input knob to give max unclipped sidechain (position '2' of 10, GR set to 'off'), leaving the 'compression' at max (I will vary the RTAS output level).
I then set the Level knob for +3 VU on the meter, which is a reasonable 'max power' level
So now, to start at +12dBu at the RTAS output and vary down, noting the gains and GR and so on as I go.
I'm writing a tool to do this, so I wanted to play about with some methods and see what makes sense. I mean, performance of a compressor is very dependant on operating levels !
So the fun begins. I should say this is what I measure - I try to understand it as I go and later after I've thought about it all for a while, I usually see the flaws with my methods
First thing I look at is the waveshapes and amplitudes at the vactrol + terminal.
'Off' shows a clean sine wave, huge amplitude (max before clip)
'Soft' (100K resistor) shows a clean sine wave, quite large amplitude
'Hard1' (blue parallel led) shows a clean sine wave, even larger amplitude
'Hard2' (1K resistor) shows a positive peak clipped sine wave, quite small amplitude
'Hard 3' (red antipara led) shows a positive and negative clipped sine wave, quite small amplitude
All of them showed strong compression availability. The on/off completely removed any GR.
Some of the questions I have so far are :
- why would a really large sine wave vactrol signal result in no GR? (in the 'off' setting)
- why would a large sine wave give less GR than the smaller, clipped waves ('soft' vs 'hard')
basically trying to understand what waveshapes give rise to what GR?
The vactrol resistance is a shunt to ground, so low resistance means max GR. High resistance means min GR.
Vactrol resistance is low when input current is high and vactrol resistance is high when input current is low.
So more current = more GR. (I assume more current = more light)
I suppose the situation is this - the sidechain signal is applied to the vactrol led - the amount of light and hence the GR produced, is proportional to the rms current of the waveform.
Then there's also dc voltages at the vactrol - I measured some there in all cases. I need to look at this more closely. Diodes rectify and thereby produce dc levels and so on. But still not what I expected
At that point I realise things aren't really what I think they are and start measuring in more detail.
