Script said:
Would too low cap values eventually mess with the circuit?
Remembered the position of that cap wrongly :-[ The cap is
after the SC tube stages and
before the Vactrol. So no messing with tubes (if any at all!?), but messing with optocoupler. Kubi mod says:
"...the
diode within the vactrol is a
variable resistor which forms a CR highpass filter with that cap... 100nF is too small for many applications. Even worse: If you push the compressor harder, more current goes through the
diodes and the resistance
lowers so that less compression happens..."
Meaning: apart from changing the resistance on the receiving side of the optocoupler (shunt to GND btw. R102 & RV101) for volume attenuation, the corner freq of the filter (on LED side of optocoupler: C104 & resistance of opto diode) itself is not fixed/stable but varies in resistance due to current? Interesting! Meaning the louder the signal, the lower the resistance in the diode and thus the higher the corner freq.? It constantly adapts, but by how much? In the worst case scenario, if corner freq. extends too far up into the audible freq. range (because of low C104 cap value), then "less compression happens" ultimately means that louder bass signals (higher current pushing up corner freq higher) get less compressed than quieter bass signals of same freq. below filter corner freq.?
Shot me or is it my head? Should I consult with a doctor or with beverages from the fridge?
Hm, if so, C104 is better as high in value as possible. 1uf fits if legs are bent or extended.
ALT HPF IDEA: How about an RC filter (stable corner freq.) between wiper of SC In pot and before the SC tube stage?
