D-LA2A Support Thread
benlindell said:
1. The Gain and Peak pots, I assume the wiper is in the middle on the board, I usually use the shield for the wiper.
the Molex connectors have the same pin numbers like a potentiometer in that place.
use the shield for pin one, it is connected to ground anyway.
benlindell said:
2. The Stereo Link switch, I just connect the left pin of each one together with a switch, and the right straight to each other?
yes - the right pin is ground
benlindell said:
3. the GAIN RED switch toggles Gain Reduction and Output I assume
true
Does anybody have the US builders BOM that was put together for this?
Also, what's the best place to source a prefab case in the US?
Thanks all
true
Cool, Thanks, I'm a little confused with the pin numbering, my boards don't have any numbers on them.
tomcat said:
What makes me wonder. Somewhere (i believe old drip docs) it was recommended to use for the pots and trimmers 2watt types!?
So just overkill there or budget/underkill here?
Volker, can you enlighten me? ;)
true, no pin numberings on the PCB. left side is one, middle is two, right side is three.
if you are unsure, ohm out pin 1 with your meter.
sure. 2W is overkill. my unit (1/4W resistors, 1/2W potentiometers) works with no problems for years now.
the potentiometers carry just standard audio line-level signal.
I have a very detailed US BOM I will be uploading shortly. I won't get to finishing it this weekend - most likely monday it will be posted here...
I finished wiring up one side of my D-La2a and I'm not getting any signal. I traced the signal around and it's getting to the peak reduction pot, the gain pot and the t4b. the 12bh7 and 6aq5a are glowing but the 12ax7s are not. I checked and they are getting 6.7V at the heaters, Any ideas? I am using NOS russian 6n2p's which are supposed to be 12ax7 replacements.
And I found a pair of 12AX7s. this thing sounds awesome!!! Trying both the fast and slow drip cells, I can't decide, they are both great.
So troubleshooting, I thought I wired my gain pot for 75k+25k pot but I can get past 1 with it, I must have messed something up. I put the 75k between the wiper and the wire that goes to pin 2 on the PCB
Transformer question here:
I'm using a transformer that has one 6.3v heater winding at 3A and a 12.6vct winding at 2A. If I only use half of the 12.6v winding (for just the 6AQ5s) is the rating then only 1A?
