no front panel pics ???drgrateful said:Here's my new D-LA2A!
disconnect the pilot lamp and the power switch (in the middle, I guess?) first ...drgrateful said:Unfortunately, while the left channel is dead quiet, on the right channel I get quite a lot of hum. I tried swapping tubes between the two channels, but the problem persists. I guess this excludes the problem source is in the tubes (am I correct?) Thanks for any suggestions!
It was the power switch! More precisely, the wires going to the power switch needed to stay away from the wires going to the limit/comp switch. Now everything is good (no more hum)! Thanks for all the useful info![silent:arts] said:disconnect the pilot lamp and the power switch (in the middle, I guess?) first ...
Telefunk: I am experiencing your same (very minor) issue. Only on one channel, just before the gain reaches 100%, I here a small pop and the VU meter starts to read full (without sound). On the other channel this does not happen. Let me know if you find out what causes this...telefunk said:But there's one tiny little issue i'd like to fix:
When i crank the Gainpot to around 3 o'clock, there is HUGE amount of gain which is great BUT just before the pot is at full, the signal drops out and the VU meters at the console where the la2a is inserted, start to read FULL, but no sound.
It doesnt really matter that much since i wont ever need that much gain but i'm just interested if this can be fixed and why is it happening.
stereokillah said:
should be help you
drgrateful said:Telefunk: I am experiencing your same (very minor) issue. Only on one channel, just before the gain reaches 100%, I here a small pop and the VU meter starts to read full (without sound). On the other channel this does not happen. Let me know if you find out what causes this...telefunk said:But there's one tiny little issue i'd like to fix:
dandeurloo said:Hey guys I have looked through the thread and haven't really seen an answer to the sound of different caps here. I am planning on building a High End version that I can use on the mix buss. stepped switches and a few mods. I am now ordering parts and wondering if anyone has any suggestions for these caps for a Mixbuss/mastering version of this comp.
Also, anyone else have any part suggestions for this kind of build?
Note: I don't care it sounds like an original I just want it to sound great!
Hank Dussen said:I suggested this already in the main LA2A threat but think it's such a great idea I'll post it again
Install sockets so you can try different caps!
telefunk said:dandeurloo said:Hey guys I have looked through the thread and haven't really seen an answer to the sound of different caps here. I am planning on building a High End version that I can use on the mix buss. stepped switches and a few mods. I am now ordering parts and wondering if anyone has any suggestions for these caps for a Mixbuss/mastering version of this comp.
What caps are you exactly talking about?
