2. Elma 24-position switches
[edited]
I installed the resistors to the Elma switches. Two of them are set for 100k log and two for 33k log (to be used in series with 68K resistor for less gain).
If you haven't used switches like this before where you add your own resistors etc.. it can be confusing.
a) Look at it as a potentiometer, a voltage divider, since this is what it is anyway, a stepped attenuator. Check out this Elma schematic from the Goldpoint Level controls website http://www.goldpt.com/schm_ser.html
b) Realize that the end-stop is before position 0, and the first resistor R1 should go at position 0.
c) The marking on the Elma part shows
0 to
22. These marking fall between switch positions and can be thought of as resistor numbers. There will be (23) resistors total when completely fitted.
d) Use silent:arts log-pot-to-switch excel document to calculate the resistor values.. http://www.silentarts.de/DIY/PM660/LogPotToSwitch.xls
