Aion FX board, 12 bucks,
Dallas Musical Ltd 1965
sounds good, Mullard transistor is OC44 from 1957, PNP germ,
going for Iommi, gettin close, just got done with the polyurethane on the fret board trick to lower the frets by raising the fingerboard,
has a voltage polarity reverse chip so you can avoid power hassle with other efffects
a few others used the Rangemaster, Mark Bolan for one,
has a switch for 3 different tone caps, simple stuff sounds good,
this would be a good one to stuff in the guitar cavity.
trimmer is to set collector voltage, 3.3 volts sounds compressed, 7 v is about the best,
