DB54 - 2254 style compressor {update 22.10.19}
Hi Everyone,
I have finished building the kit and am now testing and calibrating, and have run into an issue that maybe you all can help with.
First some background:
I have 33.8VAC at the power supply PCB input and 25.3 VDC at the output.
Following his instructions (which I have included a picture of):
1) No short between 24V and 0V pins.
2) No smoke after applying VDC.
3) BA185 pin f: 25.3VDC pin s: 25.3VDC
BA191 pin f: 25.3VDC pin n: 25.3VDC
BS283 pin m: 25.3VDC pin m: 25.3VDC
4) BA185 pin f: 22.3VDC pin s: 20.3VDC
BA191 pin f: 22.3VDC pin n: 22.3VDC
BS283 pin m: 22.3VDC pin m: 20.3VDC
5) Bias Calibration of TR3 on BA283 Card: I cannot get a reading of 2.3VDC on R7 no matter how I turn the RV1 trim resistor. I can only get a range of 8.5VDC to 9.4VDC.
Any ideas?
I am not the right person to help troubleshoot this, but I have a couple questions that might get the gears turning since no one else has responded yet.
1. Does your PSU use an adjustable linear regulator like an LM317? I don't think the slightly high voltage output would account for your trouble on the BA283 board, but it can't hurt to adjust it down to an nice tidy +24.
2. Have you double checked that you have the correct value trimpot for RV1? Maybe a greater resistance is needed to drop that voltage. Not saying that's the case, just wondering out loud.
3. The instructions don't specify which side of R7 you're supposed to be measuring. Did you measure each leg?
Sorry I can't be of more assistance...
Shoot Jman, you're a big help; please don't be sorry.
1) I set the PSU to exactly +24VDC
2) RV1 is a 5K Trimmer resistor and that is what the spec calls for.
3) One side of R7 shows 0.0066VDC, the other side shows 7.92VDC. I am using a Fluke 189 DMM with new batteries.
I double checked for any solder flows on BA283, but did not find any. I am going to send these readings to the kit designer and see what he says.
Thanks so much JMan; everything you can think of helps to eliminate another variable.
Jman, think it would hurt to put a bigger trimmer resistor in there? Like 50K?
You could certainly try. Maybe try a 20k and see if that has an impact.
Does this project come with a schematic? That would help. I suppose we could just grab the schematic for the original Neve BA283 board, that must be floating around here somewhere.
Hi JMan,
I ordered a 20K.
I found this schematic on the web and some supporting documentation.
Hi, without much analysis, two points to check. Have you measured the same voltage at the card pins with and without the cards connected ? see point 3 in the instructions. what type of transistors do you use ? In my unit I use NPN BC184c and are mounted the other way around. Emitter should go to the tag on the board from my expierence. Best
I am using BC184C transistors. Thank you so much Undos, Rob Flinn and JMan. I questioned the orientation when I began to install them, and went with a picture of someone's build that I now realize did not use BC184c transistors. I am so thankful for your comments!
The tab in the footprint is there to help you orient your transistors assuming that you are using the metal can type. Since you're using transistors in the TO-92 package, I think your best bet is to check their pinout on the data sheet, then determine their orientation on the board using the schematic. Are all the transistors BC184C, or are there multiple types? If it's just BC184C, then once you work out the orientation of one, you'll be able to place the rest easily just by using the tab marking on the silkscreen.
It's a good opportunity to practice that skill, and because the BA283 board is single-sided, it will be extremely easy to follow the connections and understand how they match up to the schematic.
Honestly, this is giving me a little itch to dig out my set of boards and build this!
my answer contains errors and was too imprecise. sorry about that. follow JMan's instructions. Check the datasheet / pinout of the transistor and then compare it with the schematic/boards. don't forget to check the other 2 boards/cards as well. good luck
