Dbm, DBu, DBv confusion...
just use a calculator.
why the log scale? because that is how the ear hears. protection from jet engines and metalica concerts,
you will see dbm on some vintage transformers
this calc allows for calcs other than 600 ohms,
handy for seeing db on both sides of a transformer
http://www.sengpielaudio.com/calculator-volt.htm
there is no better way to grasp dbm than by working with transformers,
take this Triad output for instance,  label says 26 D.B.M.
right off the bat we have weirdness, who uses the notation D.B.M. ?
answer: Traid !  :D
ok so this had us confused, this is a 20K to 600  ohm  OPT,  so which winding gets the 26 dbm assigned to it?
and is it input or output that gets 26?
calculator to the rescues,  punch in 26 dbm at 20000 ohms,  we get 90 volts,  will this transformer also put out 90 volts on the output?
chart 2 shows that 90 volts on the 600 ohm output would make 41 dbm, so that is a no go,
chart 3 show what happens when we fiddle the input voltage until we get 26 dbm at 600 ohms, 15.5 volts,
conclusion: you can take the dbm on both sides of the transformer, 20K and 600, but you must specify impedance, which will give you two different voltage levels,
90 volts input into 20K = 26 dbm.
15.5 volts coming out the 600 ohm ass end will be  26 dbm
both sides therefore can be rated for 26 dbm but it is up to the user to sort out what the different voltages will be.
if we use convention, we would assume 26 dbm at 600 ohms for the triad, in other words, for output transformers we use the dbm rating for the output, and then multiply by the turns ratio to see how hard the tube can hit the primary, which in this case is
20K/600 = 33.33 Z , take root = 5.77 to 1,  so multiply 15.5 by 5.77 = 89.5
lets see if the dbm calculator is telling the truth, 90/15.5= 5.8, yes it works,
to drive this into the ground and hammer it home look at the primary,
90V/20K=4.5 ma
and the secondary
15.5V/600=25.8ma
both sides of the transformer will take 26 dbm, the primary side will have 4.5 ma, the secondary side 25.8ma, the primary will have 90V x 4.5ma= 0.4 watts, the secondary will have 15.5 x 25.8ma= 0.4 watts,
it seems as though this dbm business is tied in with power, not voltage, since 26 dbm can be associated with 90V or 15.5 V in this case,
so dbm is a power level which uses 1 milliwatt as a ref, first derived from a 600 ohm system but not limited by a 600 ohm system,
dbu and dbv are strictly voltage levels, dbu  uses about  .775 volts as a ref, and dbv using 1 volt as a ref.
when deriving a voltage from a dbm rating, impedance must be considered
dbv and dbu voltages need not have an impedance associated with them.
dbv, dbu-voltage
dbm-power
    365.7 KB
OK for more esoterica, if dBm is strictly a power metric, than dBm at input and output of transformers would be identical since transformers do not create or destroy power, just manipulate voltage and current to keep input and output power the same (ignoring resistive losses).
We use dB for voltage ratios because it is so convenient (even for transformer ratios which is just wrong by definition).
A classic gimmick to forgive this (common) use of dB for voltage ratios is to ASSume the same termination impedance at input and output, even though that rarely is true. Maybe in the bad old days with 600 ohm nominal I/O terminations but not today when everything is bridging to maximize voltage transfer.
Sorry if this is TMI but that is the nature of the WWW.
For the OP I hope his  question is already answered (just use dBu for dBm ).
