Walrus
Sorry, mistake in my last post, it should be OA2, not OA4.
Walrus said:Sorry, mistake in my last post, it should be OA2, not OA4.
Walrus said:With the unit turned off and disconnected from the mains, with your DMM, can you measure the resistance from OA2 pin one to connector P1 pin one or P2 pin 1 or P3 pin 1 and also to output connectors earth. They should all be connected to each other and show zero Ohms resistance (or very close).
If OA2 is broken, then it's output may be at the same potential as the output of the 723 regulator, hence why you are getting odd readings. Without this nominal "zero point" at Pin1 of OA2, then you can not measure from any chassis earth and expect a rational reading.
Walrus said:What DC voltage do you have across C1 +ve -ve, and then across C2 +ve -ve?
Also what voltage do you have across R2 and across R5?
So raw DC voltage across C1/C2 would be 95.2 V. Not possible with an assumed 12VAC transformer and voltage doubler in front.Studiogearlover said:C1 47,6 VDC
C2 47,6 VDC
More likely the battery in your multimeter is low, giving such numbers ...would you reckon that the diodes CR1/ CR2 or the actual OA1 is failing?
Harpo said:So raw DC voltage across C1/C2 would be 95.2 V. Not possible with an assumed 12VAC transformer and voltage doubler in front.
Walrus said:As Harpo says, those numbers do not make sense.
What make is your DMM?
95.2 volts!!!scott2000 said:Wow this thread is a brain bender..... following with interest
So what is the voltage measuring from C1+ to C2-?
Walrus said:95.2 volts!!!
scott2000 said:so what's the problem again???
scott2000 said:Do you have a way to test caps?
