Walrus
Do you now have +12 on C4 positive and -12v on C4 negative with respect to OA2 Pin 1?
Walrus said:Do you now have +12 on C4 positive and -12v on C4 negative with respect to OA2 Pin 1?
Excellent!Studiogearlover said:Yes, I do have that .
scott2000 said:Yeah in circuit tests should be verified if showing wrong......usually it's just circuit throwing off readings but still....
ceramics are usually pretty tough......
I was also curious about C5 and 9.......the non-polars.......
Any electros or tants are usually weak links outside of any damage that could/may have been caused......... That's crazy if you were over voltaging everything as I understand..... who knows......maybe you got out ok.....
You can always check to make sure all the opamps are getting their power......
and you can Run a signal through the circuit and see where it gets funky.....
You should be pretty close I'd imagine....
Happy Easter!
scott2000 said:I've had luck tracing a signal to see what's happening in parts of circuits...... Opamps are pretty tough from my experience but they do go bad/get damaged...... especially when accidentally reversed...lol
If they're in sockets you may want to pull and re-seat them.....
I've had a bad socket before (small crack) that ran me around one time so anthing's game.....
Good luck!
Studiogearlover said:It seems that pin2, 3 and 6, 7 are all connected to those ceramic disc caps....15pf..so small value that I can not check this.
The OA4 has different values and readings on each pin's so the OA5. So there are voltages there on each pin...
...something is going on at OA3.....??
scott2000 said:I'm kinda lost /getting lost on what it is you are trying to say entirely ..... I really thing that plugging in some numbers over the schematic would really speed things up for anyone trying to help.......
OA 4 and 5 have either different pin outs or functions most likely and would result in different readings.....from 3??
Some areas of the circuit may not /should not have a dc reading.....etc...
If you send a signal/tone through, you may be able to tell where it goes awry??? Don't forget that would be an AC voltage...........
