Abe emailed me and said he used it in a session (vocals) and he said it sounded great! He said it smoothed the vocal out just right and added a nice chunkiness.Neil said:One of these is definitely on my build list. So Rev 2 should be a pretty painless build? Sounds like things have really come together!
That's what I'm doing. And I'm blowing fuses. With both trafos.Rob Flinn said:The centre tap should be a blue & green pair, the other blue & green should go one each to the other 2 psu inputs.
Rob Flinn said:If you live in the states then you should connect the primary taps in parallel. i.e 2 blacks together & 2 reds together. Connect the blacks to 1 pole of your i.e.c mains socket, & the reds to the other.
Rob Flinn said:I don't have a 160vu board but because there are so many op amps it must need a bipolar psu. Normally your mains transformer secondary will have 3 connections. Looking at the pic of the board overlay they are marked A G & A. Connect a blue & green pair to G, & the other blue & green connect individually 1 each to on of the A's.
Rob Flinn said:Also I would check that you have the diodes orientated correctly, if they are wrong you may be creating a direct(ish) path across the transformer secondary.
So here's my question (I'm a simple man with a simple mind):Rob Flinn said:when you connect a green & blue together for the centre tap, make sure they are not both on the same winding. They should be from different secondary windings. If they're not you are shorting one of the windings.... a definite fuse popper.....
