scott2000
Maybe a diagram of how you've hooked up the transformer would help too.
Search the web
I don’t think you need more than 12.6V at 2A at all - I was suggesting to check all voltages through every stage with a dummy load in place - but the low DC voltages you’ve been tabling indicate that there is a flaw somewhere in the layout(s).I do have the primaries run parallel.
You think I need more than 12.6V at 2A to run a DC heater circuit?
edit: I just reread your comment, I will look into the DC-DC converter you guys have mentioned. I just haven't gotten there yet.
Thank you!Something needed to help
How many and what tube(s) will be used? This will help with knowing the current needed.
This can matter a lot depending on the current and DC noise you can work with.
This thread seems to indicate you will need to run the output at 12.6VAC into a diode bridge OR at 6.3VAC into a voltage doubler depending on the current required
All you might need after the bridge is a cap, series dropping resistor(calculate resistance and power at worst case for >3VDC before the regulator), cap, regulator and cap. You will need a heatsink on the regulator
I will simplify the circuit and start scoping tonight. Any recommendations on sizing the filter caps? Maybe I don't have high enough values, but sims didn't see any impact by changing values.
Shame they don’t do a 6V one - 5V or 9V are the choices down there. Looks like he could use the LMS78_9-2 to 9V then the 7806 linear to drop to 6V and isolate any switching noise with filter caps between the two as well as on the bridge rectifier and the 7806 output. I’d be careful of any switching noise from the LMS78 radiating from the filament and it’s wiring to the rest of the circuit - it has from 30mV to 75mV ripple and noise. They have an output capability of 2A so well suited for this (they cannot be used in parallel to up the output current). The 7806 needs to be spaced away so the temp doesn’t go above 85deg or the output power drops like a stone.I've used these and they work excellently well. They're a bit closer to the footprint of a TO220 than some of the others.
https://www.digikey.ca/en/products/detail/gaptec-electronic/LMS78-05-2-0R/13691812
I've used these
Or these - they’re adjustable for voltage and current limiting:
https://core-electronics.com.au/dc-...Jnk8HAc0PHmMQp2soBZavei1M0K8kipkaAhSLEALw_wcBLess than $5!
Galdimmidy, dang who’d a thunk - I’d best saddle up the pony and get mahself a bundleThat's so expensive!The one on Aliexpress that i linked is 4.41eu for a 10-pack
(and another 1.41e shipping...)
With AliExpress you need to read carefully - when you go to the choose page you select your “color” which means which part of a bundle you might be buying - you might see a drill press for $2 but that turns out to be the little clamp that holds it to the bench, the press is $30! Once you get used to it, it’s fine.pack.
I've never ordered from AliExpress before, but when I went to order a new spindle for my CNC router yesterday, they did some slight of hand, and I almost paid for something I didn't want or need. I don't think I trust the prices until I click the buy button.![]()
haha, that's almost the same as what happened to me. I was shopping for spindle motors and saw a $10 ad on Google. I figured it was some introductory offer to get me to sign up. I created an AliExpress account and went to buy the spindle kit, and right before I hit the "complete purchase" button, I noticed they had switched it out for just the bracket.I once bought what I thought was a VCO chip, originally sold through Radio Shack, price was good - until I received the package which contained an original Radio Shack datasheet, faded and yellowed but in pristine condition - searched the package - no IC, just a datasheet. Hmmmm
