Typically, both the treble booster and the amp are battery powered. The ground is a bit strange since the transistors are PNP, so the ground should be positive, and the power supply negative, like in the KAT schematic.You're right.
So the negative of the battery must not be connected to "ground". Because it's a battery, both + and - are floating. At least in the one without the cabinet it uses that one side of the speaker as "ground". And because the input is capacitor coupled, it still works. That was done so that the sleeves of the jacks are connected together like a typical guitar pedal.
In the non-cabinet version https://doxyworld.com/images/documents/supersonic_doxy_spec.pdfSo where are these "off-the-shelf transformers"?
As far as I know, the person making them has one of the original radios, so they can make clones relatively easily. Are you suggesting that both versions use the same transformers?The cabinet version specifications:
https://www.doxyworld.com/images/documents/supersonic_pro_spec.pdf
says the transformers are "hand-wound bespoke replicas of the original Supersonic transformers" which sounds like BS to me.
Indeed. And that's one of the reasons I posted. I hoped someone might know them since they exist.If the off-the-shelf ones have the right taps, that's not really going to be much different. If you can find those, that's 90% what you need to make one a legit one.
The KAT transformer specs are a bit misleading now, since they for the kit only. On the other hand, they can't be totally off.
What do we actually know about the transformers?
The interstage ratio is 2:1 (page 116)
On page 115 we can see:
Since the ratio is 2:1, so 200:50-50 are probably DC resistances (not impedances). That almost matches KAT's 230:106. Also, since 200:100 = 2:1, both windings are made with the same wire gauge.
I'll try to find a similar Hammond one.
Now the output.
The impedances are 140 CT:35 (page 117), so the ratio is 2:1.
On page 115 we see:
DC resistances (presumably) 2-2.5-2.5-2:X, assuming there are only 2 windings. So the full ratio is 4-5-5-4:9.
To sum up, we're looking for:
Interstage: 2:1, RDC=200:100
Output: 4-5-5-4:9, RDC=9-?, Z=140CT:35
Or tell me where I made a mistake.
