After building two (RF) microphones with hand tools, I got a small mill and an even smaller lathe, and as a rather overambitious first lathe project, I then attempted to build the Debenham, Robinson, and Stebbings capsule. The three capsules so far are put in circuits derived from the FET847, a C414 EB P48, and the usual Schoeps (the only multipattern one). The result after a few months and several failed attempts is surprisingly good and consistent on-axis. The quick measurement (at about 30 cm/1 ft with 1/3 octave smoothing) is certainly not absolute, but it may indicate a general trend. The article claims e.g. 23 dB attenuation at 180 degrees for cardioid, which is obviously not the case here, and the frequency response for the different patterns is obviously not as flat as ‘advertised’.
Does anyone (who built this type of capsule or others) have an idea what could be a reason for the rather low attenuation and ‘bad’ pattern response?
Diaphragm tension is probably still too high for a number of reasons. Apart from that, there seems to be a rather large discrepancy regarding the “clearance ring around the capsule” between the text (1.5 thou = 38 µm) and the drawing ((1 in - 0.94 in)/2 = 30 thou = 0.762 mm). I went with the latter as it seemed more realistic.
