xeawr
I have just replaced the four rectifier diodes D7 to D10, they seemed working normally, but I replaced them anyway. Still nothing, heater voltage drops to 0.3V under load. Does that mean that the transformer is the culprit?
xeawr said:.....As soon as I hook up the load resistor(s) the 317 output voltage goes down...
This value is also too high.RuudNL said:....Are you 100% sure that this is a 15 (or 20) ohms resistor?..
moamps said:Are you sure that your 317 is implemented correctly (different pinout vs 7806, two resistors for voltage setting)?..
moamps said:It looks that "adj" and "input" pin of the 317 are swapped on the proto-board.
RuudNL said:You mentioned that you changed R15.
And not 150 (200) ohm or 1500 ohm...
Because that would explain a lot!
