Abbey, would you care to comment on the corresponding effects in headphones?
First, I hate headphones for listening, I'm utterly incapable of mixing with headphones. I use them exclusively for foldback in recording, and sometimes for identifying noises or other signal impairments.Abbey, would you care to comment on the corresponding effects in headphones?
I think you actually mean a scalar, not algebraic value.Sound pressure is not a vector, it's an algebraic value.
Quite right, ProfesorI think you actually mean a scalar, not algebraic value.
Happens to me as well....Quite right. Happens more and more often, I miss the right word, write something that I think is similar. If it comes back to me I edit the post...or do nothing...
For the less technically inclined, the accuracy of the pan pot center position depends on the accuracy of the acoustic summing of the left and right speaker(s) in space.The conservation of SPL will be verified in the median plane only, and there will be zones with much less SPL, due to cancellation.
Validity of the concept depends on how the pressures from separate sources are correlated, or how accurately two sources combine and result in doubling.
Measurements have been conducted in many studios and auditoria that show that the correlation is very good in most studios, with an average of about 5.5dB, which clearly shows that the constant-power PP is inadequate.
Correlation is not so good in many venues, with a an average of about 4.5dB instead of 6. It's predictble, since the speakers are usually much more separated. That's the reason why many live desk manufacturers opted for PP with -4.5 dB in the center position.
Thanks for the translation!For the less technically inclined, the accuracy of the pan pot center position depends on the accuracy of the acoustic summing of the left and right speaker(s) in space.
One gets used to it, 95% of all the literature I've had to read during my education as an engineer is in English, it is the lingua franca of today, back in the day, Esperanto was supposed to be the an attempt to create a common language for the world, it quickly became useless as English essentially fulfilled what Esperanto intended to do, but some people think it will be supplanted by Chinese in the future.I'm just glad you guys are so fluent. I would just give up if I had to switch between English, Spanish, and French, German,... to read forum posts.
We rack our brains trying to figure out why they were called a dome filter, only to realize it was someone's name...Thanks sdimond for the reference!! Now I understand why they're called "Dome filters" ... my mystery of the day solved!
I am interested because a lot of music these days is listened to on headphones of one sort or another.First, I hate headphones for listening, I'm utterly incapable of mixing with headphones. I use them exclusively for foldback in recording, and sometimes for identifying noises or other signal impairments.
Now, I think that the dominant effect of panning with headphones is the virtual source displacement, which, for me, completely obliterates any other effect.
I must admit I never dig much into HRTF decoders that may (or may not) overcome this issue.
I would add that the answer for the loudspeaker case is essentially a matter of physics (that are easily verified by measurements), when it's a matter of psychoacoustics in the case of headphones.
When I was at secondary school back in the 60s I was encouraged to learn German because all the best electronic books were written in German. How times change.One gets used to it, 95% of all the literature I've had to read during my education as an engineer is in English, it is the lingua franca of today, back in the day, Esperanto was supposed to be the an attempt to create a common language for the world, it quickly became useless as English essentially fulfilled what Esperanto intended to do, but some people think it will be supplanted by Chinese in the future.
I know, but who can swear the reason is it's because it sounds better?I am interested because a lot of music these days is listened to on headphones of one sort or another.
Before the 40s up to the early 80s. most engineering books used at the universities here in Mexico were translated to Spanish, some of them came from the US/Europe some were from the USSR, I have a few of those books translated from Russian to Spanish, and its amazing how the Russians have a completely different vision of the same topics, I am not saying better, but different.When I was at secondary school back in the 60s I was encouraged to learn German because all the best electronic books were written in German. How times change.
That sounds like a good invention! But yes, there probably would've been a lot of user complaints about broken pan pots, its basically like changing the QWERTY keyboard to something differentIn the 90's, I designed a spectrum-steering pan-pot, which consisted in boosting HF content on one side whilst substracting the same amount from the opposite side. 100% mono compatible.
I submitted it to Soundcraft, who took the time to evaluate it, but, although the cost was modest, concluded that it would not constitute a competitive advantage. I found out it requires some education to understand the benefits; when people see that the signal does not fully disappear on one side, they think it's broken.
It is not better. People use headphones for a myriad of practical and circumstantial reasons, not always because they sound better. There is a big market for them (not news.) For example, I use headphones on my amateur radio station because they provide 23 dB passive noise attenuation, blocking noise from cooling fans, barking dogs, marauding grand children, and my wife asking me to mow the lawn. Headphones allow consumers to listen privately, blocking ambient sound, and to listen at higher volumes than neighbors in high density living arrangements tolerate, etc. I believe it is a mistake to mix audio solely for consumption via speakers, when so many use headphones so often.I know, but who can swear the reason is it's because it sounds better?
As you may have guessed, I'm not denying all these reasons, but they're a clear demonstration that the ultimate reason for using them is not sound quality, it's practicality. Same reason why I use cans for musician foldback in recording, because speakers are imptacticalIt is not better. People use headphones for a myriad of practical and circumstantial reasons, not always because they sound better. There is a big market for them (not news.) For example, I use headphones on my amateur radio station because they provide 23 dB passive noise attenuation, blocking noise from cooling fans, barking dogs, marauding grand children, and my wife asking me to mow the lawn. Headphones allow consumers to listen privately, blocking ambient sound, and to listen at higher volumes than neighbors in high density living arrangements tolerate, etc.
It's an interesting comment. ATM, AFAIK, most mixes are intended for speaker listening, and the task of transcoding format for headphones is assigned to the final user, who has to provide a HRTF coder.I believe it is a mistake to mix audio solely for consumption via speakers, when so many use headphones so often.
