Difference in sound between a AC701k and 6072A in a ELA M251?
I've been doing some more research and from what I've found the 251 had both the shallow dish and the deep dish CK12s. Mid-1960 seems to be when the deep dish started to get used. The 251 I compared the 414 EB to, should have the deep dish because it is from 1961.
https://gearspace.com/board/showthread.php?p=14012532
Also, I haven't found any indication that AKG used the shallow dish CK12 in any of their later microphone models after the 251.
So, unless the 251 was made pre mid-1960 and sold in 1961, both it and the 414 EB should have the deep dish version of the capsule.
EDIT: The 251 in those two shootouts are the modern reissue by Telefunken USA. If it is from the early 2000s it might have an original CK12 in it, otherwise it would be a recreation.
@Double G
Nope…
All the AKG-Telefunken ELA-M 250 & AKG-Telefunken ELA-M 251 (E and non E) microphones had the CK-12 Deep Dish Capsule and T14/1 Output Transformer
As you can see by the attached schematic all of these ELA-M’s (E and non E) were “officially” dated at 1961
The AKG – Siemens SM 204/3 was a Cathode Bias microphone like the AKG-Telefunken ELA-M 250 & AKG-Telefunken ELA-M 251 (E and non E) microphones, but from the other hand it has the CK-12 Flat-Shallow Dish Capsule and the Rohde & Schwarz V-2545 Output Transformer
Also the AKG – Siemens SM 204/3 had a different circuit than the AKG-Telefunken ELA-M 250 & AKG-Telefunken ELA-M 251 (E and non E) microphones had and it is more “close to” an AKG C-24 Stereo Microphone circuit or to a C-12 Microphone System circuit…
Your AKG 414 EB microphone although it was produced back at 1976, it had by designer’s choice the CK-12 Flat-Shallow Dish Capsule, because back in this time at the AKG AG they tried to re-produced the “vintage vibe” of the 50’s C-12 Microphone System, but this time used FETs…
If you want like it to see it in a synth "analogy", it was something like the Moog Voyager monosynth, as the Moog Co. tried to replicated with the Voyager the sound of the legendary Moog Minimoog with more modern features…
Now as I wrote you before if someone’s like to have a more extended range of the low end in the AKG-Telefunken ELA-M 250E & AKG-Telefunken ELA-M 251E circuits and in the AKG – Siemens SM 204/3 circuit with a 6072A / 12AY7 tube, he can easily use 2 Signal / Rectifier Diodes (0.6 Volts), wired them in Series and use them as Cathode bias element in the place of the 1k8 Cathode Resistor
He can either use a ECC81 / 12AT7 tube with a 2k7 Cathode Resistor or just a Red LED (1,6 Volt) as Cathode bias element in the place of the 2k7 Cathode Resistor and then he will get again more extended range in the low end with the ECC81 / 12AT7 tube…
In a more “advanced way” he can either wired the ECC81 / 12AT7 tube “en parallèle” and then he can use just a White LED (1 volt) as Cathode bias element…
As you can see as DIY’er there are many more “tricks and tips” that someone’s can do today, than they couldn’t have been done by AKG AG, back in the times of ‘50’s and ‘60’s…
Nope again…
The Telefunken Elektroakoustic USA ELA-M 251E microphone(s) HAVE NOT any original AKG AG “Brass” CK-12 capsule in them, as they nether they had or have…
Since they haven’t (as Telefunken Elektroakoustic USA) reviled who is the original manufacturer of the capsule, it may be a Chinese one…
  • AKG - Telefunken ELA M 250 - 251Ε Schematic.pdf
    149.5 KB
You don't need the AC701 to have a better tube than the 12AY7. For a new build or a diy mic, try a EF86 or similar pentode. I prefer the C12 or U67 bias instead of cathode bias of the 251
Are you using the EF86 triode connected? Pls show us your pentode circuit for LN
If pentode connected common cathode (like 251 & C12 etc), sensitivity would be VERY high ... but also rather distorted and noisier.
@ricardo
Probable LevinGuitar «typically» means by his point the extra ordinary “pentode wired as triode” mod. as he points out that he’s like the Neumann U-67 grid-leak bias, but it is good here to be said that the EF86 tube in “pentode wired as triode” mod. can be biased ever as fixed-adjustable bias (Cathedral Pipes Notre Dame Tube Condenser Microphone) or as grid-leak bias (Neumann U-67 Tube Condenser Microphone) or even as cathode bias (Microtech Gefell M-92.1-S, Microtech Gefell UM-92.1-S, Microtech Gefell UM-75 Multi-pattern Tube Condenser Microphone).
    346 KB
    414.3 KB
Absolutely correct, true pentodes are not well suited for this position due to their characteristics.(y)
But I am pretty sure that member @LevinGuitar knows this too, as he has already built several Mics. He will mean pentodes wired as triodes...
Right! Pentode wired as a triode in U67 or G7 mics, nothing new.
I have compared AC701, 6072, EF86 and more tubes in the same mic (SP T3) and the EF86 did sound a little "bigger", more in your face, but also a bit brighter. The 701 seemed more flatter, a really nice even for the 797 k67. The GE 6072 did not sound as good as the previous ones (to my ears). Maybe with a good ck12 things would be different.
It's important to mention when swapping tubes in the same microphone that you can get different results in another circuit. Besides optimizing the bias of every tube, the match with the capsule and transformer is a determining factor.
If you wan't a reliable pretty cheap tube EF86 is a great choice. A NOS Valvo, Telefunken or another Western Europe tube is well worth the extra cost. You don't need to aim for an EF806S.
I think many high quality NOS 12AT7 sound just as good or better than GE6072. All the RCA 6072 I've tried (at least 15) have been way too noisy.
Besides B and H voltage differences, both EF86 and AC701 have been succesfully used in a same mic, matching capsule, transformer, and rest of the circuit in M269/U67. The bias voltage (and type) was a bit different in 269 vs 269C, right.
@ricardo
anyone got views about the MG method for 'triode connection' with G2 & G3 together ... vs the more usual method used by Neumann with G3 connected to cathode.
Just to set something clear and straight about the “pentodes wired as triodes”, I have to tell you that Georg Neumann had used both of these topologies…
In the Neumann U-47 & U-48 microphones as you can see he wired G2 & G3 together with the anode of the VF14 tube…
In the Neumann U-67 microphone more typically he wired G2 with the Anode & G3 with the Cathode of the EF86 tube……
Don’t forget that the Microtech Gefell AG were and are the original Georg Neumann’s colleagues in the original Georg Neumann’s factory at Gefell, they had a physical bond with him ‘till 1958 and they always honorable referred to him as their ex-leader.
The Neumann - Gefell CMV563 and the Neumann - Gefell UM57 microphones were co-operation between Georg Neumann with his ex-colleagues at Gefell…
And as you can see for the Neumann - Gefell CMV563 and the Neumann - Gefell UM57 microphones, they had choose the EC92 tube, which is the “little – half brother” of the “double brother” ECC81 – 12AT7 tube
IIRC, EF86 triode connected, usual method, has characteristics very similar to ECC83 or maybe 82
When you connect the EF86 – EF806 tube in the typical “pentodes wired as triodes” topology (G2 with the Anode & G3 with the Cathode of the EF86 – EF806 tube) it has Ra = 16K and μ factor = 34, but the EF86 – EF806 tube characteristics as "triode" has nothing to do with the other typically triodes characteristics, as the grid lines are very “isometric”…
    399.8 KB
    335.9 KB
    341.2 KB
  • Telefunken EF806S 1964.pdf
    358.1 KB
  • Philips EF86 1956.pdf
    317.6 KB
@tomas.borgstrom
I Diddo with you to this point!...
For me the “optimal” output transformer that “match” pretty close the 6072A – 12AY7 tube (if you wired it “en parallèle”…) or the EF86 tube in a “pentodes wired as triodes” topology (G2 with the Anode & G3 with the Cathode of the EF86 – EF806 tube) is a Moby Transformers ~ V2545 (C12, SM204) Ratio: 12,3-1 or the CineMag CM-9766 Microphone Output Transformer Ratio 12-1
The Moby Transformers ~ T14/1 (C12, ELA M 251) Ratio: 11,5:1 or the CineMag CM-2480 Microphone Output Transformer Ratio 10.5-1 makes “match” better with the ECC81 – 12AT7 tube or any other tube which have lower Ra
Just for fun but also quite interested as all of these deferent companies and factories use deferent capsules, deferent tube wired topologies, deferent components, deferent output transformers etc, etc, etc. for their microphones
VK Shootout: ELA M 251-Style Microphones
