RuudNL
In most designs (even in professional equipment) we often see this input configuration:
Resistor values are usual R1=R2=R3=R4, 10 K or so.
IMHO this is incorrect, because:
The inverting input of the OpAmp is a virtual ground, 0 ohm.
The non-inverting input of the OpAmp has an almost infinite impedance.
The result of this is that one input leg has an impedance of 10 K (R1), while the other leg has an input impedance of 20 K (R2+R3).
A better solution would be: R2=R3=10K, R1=R4=20 K. In this case both input legs have an input impedance of 20 K.
Any thoughts about this?
