Following this thread with much interest. We have a Neve 53 series board here. Also a "Green Phone" SABC 54 type board with 4 discrete 34127 channels that we would like to add direct outs to. Definitely into buying some boards.
Winston O'Boogie said:Speaking of improvements, I can't say I'm too happy with the bias spreader maintaining bias stability since there's no thermal coupling or anything. I think TR7 and TR8 bases need to be limited to a 2V spread max to avoid silicon death.
Idle current could easily be 30mA peak for the output and have a healthy class A life most of the time:
30mA peak with worse case 200 ohm load being 6V peak plus another 4dB from the transformer so, + 12dBu.
Yes they will; they have to sustain the myth.Winston O'Boogie said:Considering the very low level across this cap, I very much doubt there's any resulting distortion
The Neve guys will tell you differently.
I believe you know Bateman had to make measurements in unrealistic conditions for a well-designed piece of gear. Applying volt level across a coupling capacitor is not commensurate with typical operation. Only notable exception is passive x-overs.Myself, I will say that there's a definite difference that is measurable with standard test gear. Not sure what Cyril Bateman said about the distortion through tants but there is some at these signal voltages.
Winston O'Boogie said:Loading 70 ohms would be fine. The output transistors will need heatsinks anyway and it seems folks have made 1081s using individual and easy to buy heatsinks rather than the custom flat piece of aluminium with isolated top hats underneath.
If we can current limit these to avoid death than that still leaves plenty of current to drive 70 or 50 ohms, just means that the amp switches from class A to AB earlier on. That's what it was in the 1081 so.![]()
Winston O'Boogie said:The 10ohm B+ feed resistor (R91 on the Neve 1081) makes a pretty good fuse. If you go for 1/4 watt as original, it'll burn up before my contemplated led clamp would kick in so that sorts that.
Winston O'Boogie said:I don't understand where you got the +18dBu into 15 ohms from, where in Neve-land are these tasked with driving a 15 Ohm load?
Winston O'Boogie said:Started assembling these parts into a layout
Winston O'Boogie said:First pass of the Neve 340/440 board with associated components. This is 35mm X 87.5mm and single sided for added vintage-ness.
Winston O'Boogie said:Haha, yep if takes a bit of getting used to. No I don't use a stylus, just my fat podgy index digit!
I was on a smallish Lenovo tablet and just really zoomed in to get the traces where I wanted. I set the raster size to 25 thou which got the components on grid and it snapped the traces to where I wanted for the most part.
I don't think it'll be my new primary layout app but it was nice to just sit on the sofa painting away with my finger.
Cheers Ian
Winston O'Boogie said:Looks to be cooling down across the country as of tonight.
