Discrete OpAmp Test Jig
I am sorry I can't provide a  solution that doesn't include cutting traces.
If there is interest, this is something to incorporate in a revision along with a corrected footprint for the switch  ::)
Carsten
maybe this will do the trick?….sorry,don´t know where the 7th pin is located….
Built in ten minutes with veroboard,solder nails and sockets.
Best regards,
Udo.
Edited typo….
    88.9 KB
Thanks for the great suggestions!
Anyone know where you can buy those sockets with standoffs here in Europe?
I have to agree, Udo came up with a clever  creative solution I didn't think of  :eek:
If Farnell is an option for you, you can copy-paste the order-code from the BOM in their search mask  8)
Otherwise I can only suggest to drop Volker a mail...
Carsten
Carsten
Yes,asking Volker is a good idea,he helped me with sockets and pins several times.
@ Carsten:Danke für die Blumen ;D
Udo.
I finally reviewed the board and ordered a new batch:
The rotary switch fix is no longer needed  8)
Please see my BM listing to order some spare boards.
Carsten
[EDIT: FIXED LINK.]
I just got a question about the switch positions and their functions via PM, so I thought I would answer here for all:
Switch positions 1 and 2 are a non-inverting amplifier with unity gain and +20 dB, respectively. The other two switch positions configure the DUT as an inverting amplfier with either unity gain in position 3 or +60 dB gain for position 4. The silkscreen has these switch position printed on as well.
Hope this was clear enough  ;D
Carsten
