elskardio
Are the opamp's transistors easy to identify?
I did that. All tested ok.From photo, looks like xsistor #s are scrubbed off. There are only 8 transistors in the circuit. Surely they can be tested EBC and a quick beta check. One will turn up bad.
Yes. Dc coupled.Just thought of some thing else. there seems to be no coupling caps on the board. It may be dc coupled. So your EBC readings and beta measurement may be misleading. I know a pain in the >>> Did you check the transistors out of circuit?
Open junction looks correct because another junction is turning on
I measured each transistor out of circuit.
Yes. I can bring you up to speed if you like?Without reviewing all previous posts, have you checked all the supporting circuitry.
yes I am on it.You need to do a ccaudle says, get a sheet of paper and take down and record all the measurements suggested on a good unit and compare with a defective unit.
I also can’t continue to desolder and resolder the discrete opamps in and out for testing.
