If your distressor cant handle the level you are feeding it your gain staging is either completely wack or your distressor is broken.
unity gain should read around 1.2 VAC on a meter. Set up a keyboard or a bass into your usual mic and preamp setup and get a steady tone going and adjust the mic pre so the output shows 1.2 ish volts AC on your multimeter. This is line level.
Without touching the gain on the pre, plug it into your distressor and put it into bypass. Id start with the output pot halfway up or so, connect the multimeter to the output of the distressor and then turn up the input knob so the meter shows 1.2 ish volts.
Plug it into your monitoring. You should NOT be hearing distortion. When you take the unit out of bypass, if you hear distortion then its the limiter and not the input buffer. Id go through this test and figure out what you are hearing. Ive had distressors pretty much since they came out and have never ever ever had any hint of low headroom problems on any of mine (or heard of anyone else with that problem). Not saying yours isnt busted, just that its not a common problem, I would tripple check that your gain staging in and out of the box is correct before messing with the input circuit. Distressors have a silly name and an even more silly reputation, those boxes are more than capable of super super clean limiting, no problem.
dave
dave
