oran.outan
English Version***
For the design of the front panel I used: Front Panel Express Your Expert for Front Panels and Enclosures you can do a .fpd usable 'as it' for most of the industry.
for the PCB drawing : KiCad EDA free and great software/ the common file for doing PCB is Gerber (.Grb) that you can send to any PCB industry (JLCPCB, PCBway,...)
- NRG 1u case : Kopie von NRG CASE 1U (300mm Tiefe), 69,81 €
- you send him the 2 files in NRG_3X_500H folder (link to this thread) ::
n front panel I have add the thread for screw the 500 modules + hole for 3mm Led on the right.
I prefer not to add switch hole and frontpanel/case bracket hole as size and position can be specific.
- 1xIEC connector + 3x XLR (Male & Femelle)
https://shop.frontpanels.de/IEC-Connectorhttps://shop.frontpanels.de/XLR-female-connectorhttps://shop.frontpanels.de/XLR-male-connector
You can also add the L bracket (for top/bottom)
https://shop.frontpanels.de/navi.php?a=260
In my case I just use L profile aluminium bar that I find at Leroy merlin.
BOM for the PN48PSU above on that thread
https://www.reichelt.de/de/fr/transformateur-toro-dal-30-va-2-x-15-v-2-x-1-0-a-rkt-3015-p15275.htmlhttps://www.mouser.fr/ProductDetail/Triad-Magnetics/VPT36-1390?qs=wkKrz7WmEgM2EIrgD3Tzhw==
yes,
Yes,
Not possible to put a Switch side to the LED, not enough place. but you can put a Switch on the other side... A Swicth on a side and the Led on the other Side pf the rack...
that's it !Et comment sont stabilisés les modules 500 : par leur fixation en façade + 15 pin à l'arrière uniquement ?
You have to send a mail to frontpanel (Frank) and ask him a invoice:Si je récapitule :
* achat frontpanel.de du rack 1U 19" : auriez-vous une réf à recommander ? je ne m'y retrouve pas sur son site
+ envoi à Frank du dossier 500Edge pour obtenir les panels avant et arrière prédécoupés
Yes, his mail on the white market.* achat du PN48PSU et du Oupiin 8706-30G00D à volker aka [silent art]
You need a CC 2x18v / 36v CT like:* achat du transformer
You need to order the 500 edge. it's that small PCB where you come solder the Oupiin (EDAC type) connector...* achat des autres composants pour les 3 PCB 15pin, et des connecteurs XLR et cshuko
Yes,* assemblage des 3 PCB 15pin et autres connecteurs
* assemblage de l'alim
* finalisation du boitier (renforts + trous en front)
"In place of the Led a switch could be add with a small size one, but not so much space..."
=> j'ai l'impression qu'un petit switch à levier pourrait tenir à côté de la led
yes,
Yes,
bonjour Matho
Pour le design de face avant j'utilise : Front Panel Express Your Expert for Front Panels and Enclosures qui sort un fichier .Fpd que la plupart des fabricants vont pouvoir utiliser tel quel...
Pour le dessin de PCB : KiCad EDA
le format de fichier conventionnel pour l'impression de PCB est Gerber. si tu as un fichier .Grb tu peux l'envoyer à n'importe quel fabricant de PCB (JLCPCB, PCBway,...).
oui c'est ça !
Tu envoi un mail à frontpanel.de (Frank) et tu lui demande un devis avec infos de paiement:
- NRG 1U Case : Kopie von NRG CASE 1U (300mm Tiefe), 69,81 €
- Tu lui envoi les 2 fichiers dans NRG_3x_500H
Je te le remet ici : ajout du filetage pour le montage des modules 500 + la led à droite.
je préfère ne pas ajouter le trou du Switch car le diamètre dépend du Switch que tu utilise. Pareil pour les trous/points de fixation entre le frontpanel et le boitier (entre le haut/bas du rack et la face avant pour renforcer...). mais c'est quand même nécessaire de mettre des renforts...
- 1x IEC connector + 3x XLR (male/femelle)
https://shop.frontpanels.de/IEC-Connectorhttps://shop.frontpanels.de/XLR-female-connectorhttps://shop.frontpanels.de/XLR-male-connector* achat des attaches frontpanel with top/bottom (je ne vois pas trop où trouver ces attaches)
https://shop.frontpanels.de/navi.php?a=260(perso, j'ai fait ça avec des équerre alu que tu trouve à Leroy Merlin... que j'ai taraudé, mais très pratique si pas équipé en bricolage)
oui, * achat du PN48PSU et du Oupiin 8706-30G00D à volker aka [silent art] --> tu trouve son contact dans le whiteMarket
Tu trouvera le BOM (liste composants) pour le PN48PSU un peu plus haut dans le fil de discussion...
oui, il te faut un CC 2x18v / 36v CT, genre:
*Il faut que tu fasse une commande de PCB pour les 500edge (le petit PCB sur lequel tu viens souder le OUpiin et le reste) /// je n'en ai plus en Rab et ne peut pas t'en dépanner...
--> fichier 500 edge dans le 1er post.
pour les fixer/tenir, j'ai utiliser une équerre alu...
* assemblage des 3 PCB 15pin et autres connecteurs === OUI
* assemblage de l'alim === OUI
* finalisation du boitier (renforts + trous en front) === OUI
---> pas possible à coté de la Led mais possible de l'autre côté :: d'un côté du rack tu met la led, de l'autre le Switch...
Ca peut se faire si vous etes pas pressé ! je fais ça sur mon "temps libre"...
Après, pas sûr que ça soit avantageux par rapport à un produit du commerce! Mais possible...
Envoyez moi un message pour en discuter si c'est ce que vous voulez...
0-0
