Yes, I use the 62/36/2 0.0015 Silver Bearing Soldier (64-035)So the local RadioShack has some 62/36 solder at 0.015". Is that too thin in your experience?
o3misha said:I would never use resistors with value higher than 100M-200M for U47-ish mics with old tubes. 60-100M is enough for me.
AusTex64 said:MDeath,
Here is the correct component list to build "U47 alternate tube with remote polatrity switching", that will match the components you received from AMI:
R1 - 1G ohm, .5W
R2 - 100 ohm, .5W
R3 - 29 ohm, .5W
R4 - 100K ohm, .5W
R5 - 1G ohm, .5W
R6 - 1M ohm, .5W
R7 - 1M ohm, .5W
R8 - 51K ohm, .5W
R9 - 100M ohm, .25W
R10 - 1G ohm, .25W
C1 - 1uF, 250V (brown cap in AMI parts kit)
C2 - .01uF, 250V (green cap in AMI parts kit)
C3 - 1 uF, 250V (brown cap in AMI parts kit)
C4 - 1000pF, 250V (yellow cap in AMI parts kit)
C5 - 10 nF, 250V (green cap in AMI parts kit)
Note that .01uF and 10nF are the same green caps. I am not sure why he labeled them differently in the drawing.
I used all the parts Oliver supplied and my mic sounds ****in' GREAT!!! I didn't spend one minute searching for alternate components.
Good luck,
Robert Mokry
Austin, Texas
You wrote:
<Ok, now I am thoroughly confused. Those look like the values Oliver sent me, although I only got 9 resistors, not 10. I wasn't expecting any resistors or caps, so I just saw it as a bonus. And since most of the values did not match his schematic, once again I assumed Oliver just put some surplus parts in a baggy for me out of good will. But your telling me that's what his schematic is supposed to be? That's very divergent from a U47 schematic. I just don't understand...>
I was confused too, don't feel bad. I was also pleasantly surprised to receive the components that were selected by Oliver. They are very high quality, IMHO. When I started measuring the included resistors and discovered they did not match the AMI schematic, I wigged out and called Oliver. He quickly set me straight. I'm just repeating what he told me AND it will be in writing for other builders to reference.
FWIW, the AMI kit is not intended for building a "dead stock" U47 clone - you're building a hybrid U47 style mic mic with U47 style capsule, output transformer, head basket and body, but with different preamp tube and remote polar pattern control (BIG difference). Far from a "stock" U47 with hard switched cardioid and omni pattern selection. Look at what Wunder Audio and Lucas are doing. That's the spirit of this build, I think. The remote pattern control/polarity inplementation is kinda similar to the M49 method. In this case specifically, to the UM92 link I posted yesterday.
I've attached my component layout/wiring diagram for "AMI U47 alternate tube schematic with remote polarity switching on the power supply unit". This is how my working AMI mic is assembled. BIG ASS DISCLAIMER - I am not a tube mic expert nor electrical engineer. Use this diagram at your own risk. Hope it helps.
Robert Mokry
Austin, Texas
Melodeath00 said:Robert,
I have nothing against Oliver. He's a very nice guy, and has been helpful. I will say that in my experience, he is very hard to get a hold of - this is probably due to, as you say, lack of minutes in the day. And it took a few shipments before my order was completely correct, but Oliver was great and never asked me for more shipping money. I also greatly appreciate the opportunity he has given us to build mics with quality parts like this.
However, linking to an incorrect schematic on the page dedicated to selling a DiY kit seems like a pretty big oversight to me. As a result, I now have to rewire the PSU, and I wouldn't have even known if not for having this thread and your reply.
I'm no expert, but remote pattern switching is achieved by varying the voltage sent to the rear diaphragm of the capsule. I don't see why this would affect tone of the mic. In cardioid, the rear will get 0V, just like a real U47. In fact, one of the guys who works at AMI (or used to, at least) mentioned that it should not affect sound when I asked in an email about a year ago.
But also, I don't see why any resistor values need to be changed to achieve remote switching. You need to add some components to the circuit so you can apply a voltage to the rear diaphragm, but I don't see why you need to change the existing audio circuit. In other words, unless I'm very wrong, it seems you could leave the U47 portion of the circuit be. Maybe someone here can chime in? It's almost as if we were sent the component parts for the UM92 and not for the U47.
I'm not passing judgement on the kit or the mic. I'm sure your mic sounds awesome, is int he U47 ballpark, and that a mic is mostly its capsule anyway. I'm simply expressing that I feel a bit mislead here.
Thanks again so much for participating in the thread! Maybe I just need to call Oliver to get to the bottom of this.
Melodeath00 said:Ok I should have a very cheap BV8 and K67 on the way just for testing. They probably wont be necessary, but this is my first build so I want to be very careful.
AMI kit is still on the way.
Can anyone let me know if this is a good soldering iron for mic building and PCB work? http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UC/ref=sr_1_2?ie=UTF8&qid=1367888638&sr=8-2&keywords=soldering+iron+weller#productDetails
If it's not, could you suggest another? So far two people have mentioned that it doesn't have temperature control/feedback, so maybe this isn't so good? Much appreciated!
I wound up getting the WES51 Analog instead!tonycamp said:Melodeath00 said:Ok I should have a very cheap BV8 and K67 on the way just for testing. They probably wont be necessary, but this is my first build so I want to be very careful.
I burned through 2 of these irons in 2 months, the base still works?? :-\
It would be quite interesting to do a real scientific test to see if remote pattern switching sounds different from on-mic switching.
Oliver uses 1G for Lucas CS4. Andreas Grosser uses 100 M for Vox-o-rama, as far as I remember. Neumann used 60M-100M ( its not true that Neumann has not got possibility to use resititors with bigger value. They avoided to increase low end. First U47s has different grid resistors and coupling capacitors value) There are many other important things besides" low end". I personally don't like big grid resistors because of unpleasant stiffness in sound and excessive toughness, especially with old tubes.AusTex64 said:o3misha said:I would never use resistors with value higher than 100M-200M for U47-ish mics with old tubes. 60-100M is enough for me.
Misha,
I have seen many of your posts and obviously you know what you're doing. Why do you think Oliver supplies 1G ohm resistors with his kits, and also appears to use them in the Lucas design? I understand it has something to do with frequency response. I notice 797 Audio also used 1G ohm resistors with a Wima cap in my MXL V77's, along with Teflon PCB insulators and solid silver wire for the connectors from capsule to tube. Looking to learn something here. Thank you.
Robert Mokry
Austin, Texas
I'm not sure exactly what test I have in mind either. I know the noise difference is very real, but I'm having a hard time believing there's a difference tone-wise that you couldn't make up for with altering voltage on the capsule. Again, though, I'm no expert. What difference do you find in your Horch RM2J?micaddict said:It would be quite interesting to do a real scientific test to see if remote pattern switching sounds different from on-mic switching.
I don't know what kind of test you have in mind exactly, but AFAIK the noise difference is a fact and the tone difference (some mics have both, so it's easy to compare) is more than obvious IME (Horch RM2J).
Here's a U47 "clone" that has both:
http://www.wunderaudio.com/cm7-gt.html
You're saying they had access to larger than 100M resistors when the U47 was invented? I'd love to know more about the Lucas CS4. I've heard it's pretty much dead on to a U47 when you use the exact same capsule.o3misha said:Oliver uses 1G for Lucas CS4. Andreas Grosser uses 100 M for Vox-o-rama, as far as I remember. Neumann used 60M-100M ( its not true that Neumann has not got possibility to use resititors with bigger value. They avoided to increase low end. First U47s has different grid resistors and coupling capacitors value) There are many other important things besides" low end". I personally don't like big grid resistors because of unpleasant stiffness in sound and excessive toughness, especially with old tubes.AusTex64 said:o3misha said:I would never use resistors with value higher than 100M-200M for U47-ish mics with old tubes. 60-100M is enough for me.
Misha,
Robert Mokry
Austin, Texas
