scott2000
Gorgeous.
Thank you for saying so. If perfection was paramount (ought to be) I'd of made jigs like PRR? posted few months back...It is just old school wiring. Not messy.
Yes! Can't get much nicer than that--a structure meant to keep clean the runs in a superstructure. Looks the best!old school tie bars are still the best
Building me some Dunning-Kruger rainbow bridges!The leave no stone unturned approach, the over-thinking
Quite the opposite- Came to terms with the fact I've never finished anything that has been truly objectively difficult. Want to see if I can actually make something that intertwines unknown territory with maximum deferred gratification-- completion is critical for many reasons.I have a feeling Boji, that you'd like the project to go on for good
Tie bars, lacing bars - the terms are pretty much interchangeable. These one I got from Canford Audio here in the UK. They use them on their own custom panels. I already had the panels from another supplier; i just needed the tie bars. You are spot on - the ends are tapped. I just drilled a couple of countersunk holes and screwed them in. As well as making things tidy and supporting the wiring, they act as strain relief on the connectors. The tie wraps shown in the pic are rhe commonly available type but they look a but too big to my eye especially compared to traditional lacing. I recently found some that are about half the width. They look much neater.80hinhiding said:I searched tie bar, and found they're referred to as lacer bars as well. Ian, yours look as though they must be tapped for a screw, then screwed in place from the outside of the back panel. Neat option for keeping things... neat. I came up with a method of my own when I did my back panel (with tons of XLR and TRS I/O connectors) but will try this technique in future.
Adam
Underestimated lengths so had to use all the colors. :I love that stuff. I only use four colors for four channels.
The first few I used a syringe and nail polish, butDo you do the silk screen?
Thanks for your support man! Kinda sort of close. Still need to code-up and make cables for mute/solo logic and buffers, fader faceplates, integrate monitor controller. Once it's actually passing mixes I ought to build some aux returns, as there's 6 empty backplane slots available, but I reeeely need to get back to making music first!Your getting very close.
