right, I should have clarified, an instrument level amplifier.
I didnt much understand the need for a reamp box until I heard a record a friend did and went out of my way to ask him how he got the phaser sounds on the record, he mentioned using the (TM) box and that was the first I heard of it and this was a billion years ago. I eventually found my own non (TM) solution to the problem and was blown away. If you havent tried one of these, I'd suggest thhat it would be worth the time if you use a lot of effects that were designed with an instrument level in mind in your mixes. It makes a big difference for me, it might make a difference for you, might not...
dave
dave
