You
should pat yourself on the back -- it's a pretty elegant PCB!
... especially as it's ' issue 1' , as it were.
I don't 'feel' there are any significant RF issues... it tunes well, and there is very little noise.
One little quirk I have discovered ... the K67 capsule in my 'end address' version need to be connected one way round.
The connection to the bridge balance point - the low voltage 'end' - needs to go to the edge termination, with the higher voltage to the centre terminal...It's function of the proximity of the edge connection to the head basket, which can cause some handling noise.
It's still a bit strange getting used to being able to operate the mic with the head basket removed - if necessary- without incurring horrendous hum!.....still coming to terms with a low impedance LDC condenser capsule of course.
(You also no longer need a double mesh on the head basket either)...
I think C4 is OK where it is... it's easy to fit, and to change it if necessary ...I think in between the cans might be less accessible....
Do you have the Gerber files for your 'pads' version (which I think will be RF.AMX9 ?)...
I think the layout looks really useful, and it should be possible to add either pad by just fitting link to the pad header....
In the case of a BM800 it's no big deal to simply unscrew the case to gain access to the link......a lot easier than fitting a switch somewhere on that tiny casing!
I know you're continuing to develop ideas with the EQ, but I would like a copy of the non EQ version - but with pads - if it's possible? ...Only if it's easy to do though!
Thanks again for your efforts.
I think we now may have a version that might just be ready for others to try and build?....
