I have no idea whether much (if any) work on this topic had been done beforehand, but had i been the (only?) one who prompted that research / analysis, at the time?
I do recall having read about the overly-bright K67/K87 capsules being "tamed down" in the electronics. I figured if Neumann themselves "can" do that in their own circuit, and thus it's not "heresy" to alter the response of a given capsule, couldn't a similar effect be achieved with the nearly-ubiquitous Schoeps circuit?
PS: To achieve a high-shelf response, wouldn't one need a resistor in series with the capacitor, across the drain resistor? The cap alone would cause a (monotonous?) high-cut. But i stand to be corrected, of course
ricardo said:In https://groups.yahoo.com/neo/groups/micbuilders/files/Ricardo/ChinaMod%2BU87hybrid/ I analyse adding bits across the drain resistor in detail. You have to join.
Since then Abbey has provided me with an LTspice model of U87 which is more accurate than what I used with the linear circuit analysis DOS programme I wrote circa late 80's. This beach bum needs to get off his arse and update ChinaMod+U87hybrid.doc but the findings there are all still valid. In fact my mod is ideally suited to EQ for AMX8 with the capsule rogs used, where a HF shelf is appropriate. Only a single cap is required.
I second everything Abbey & Khron says about Henry's EVIL resistors including stuff about Minimum Phase which was of great interest to me in 1980. I would add that my EQ mod REDUCES NOISE while his increases noise. If you look carefully at Henry's measurements, you'll see that he actually does have increased noise.
