gyraf said:
..so is it the "dead capacitance" of the CK12-style design that swamps noise figure, or something else..?
Jakob E.
I'm not sure I understand what you mean by 'dead capacitance'? ....
In the present configuration, the noise floor of the circuit varies considerably - depending on the inductor settings.
I tried removing the capsule and replacing it with a similar value capacitor to the 'load' capacitor - in this case 68pf.
It was then possible to adjust both inductor slugs to find a
very specific 'null' point where all the noise virtually disappears (It's then at least as good as my Schoeps circuit)
T1 and T2 both appear to be at their maximum 'tuned' settings at this null point.
Sadly, this is not the same null point that provides the maximum audio output with a capsule fitted, with an audio source used for calibration. There is an increase from the minimum noise floor by around 10dB or so at the maximum audio output setting.
The overall signal/noise ratio is therefore determined by the sensitivity of the capsule employed. --
My 3micron C12 and K.67 samples are about 10dB more sensitive than the K47 - or indeed my 6 micron C12 from Alibaba.
And the signal/noise ratio of those latter two is obviously worse by the same factor.
I've not been able to discover so far what causes this oscillator noise. The oscillator output looks to be pretty sinusoidal - especially when measured at either end of the T1 secondary winding.
The fact that it is possible to tune out most of the noise at the max 'tuned' settings does rather suggest that the signal at the gate of the infinite impedance FET is what is causing problems.
Looking at the tiny 'residue' of the oscillator signal at both the drain and the source of the FET does show some non-linearity - and the waveform at the drain is slightly different from the source. At the minimum noise 'null' point these tiny (a couple of millivolts) residue signals appear to be at their maximum amplitude .
There may well be ways of further improving the application of the FET in this circuit -- it is acting as both rectifier and phase splitter - but I fear the technicalities of how best to progress may be a bit above my 'pay grade', engineering wise.
As I have mentioned before, the circuit works way better than I had ever imagined when I first sketched it out - especially with high sensitivity capsules - and I think we're now probably moving into the realms of the law of diminishing returns, trying to take such a simple concept very much further..
It would be nice to try and discover how the inductor tuning settings are affecting the FET noise output though.....
