shot
So I finished my mic!
In fact, I've made two mics.
I've tried 2N5457 before J113 got delivered and it sounds same as J113.
Since I've socketed all the transistors, I had a chance to try different transistors in it. For Q2 and Q3 it didn't matter what I've installed. At first I went with matched pair od BC557C, and after that I tried 557B, 560B, 560B. Matched and unmatched. It just didn't produce any different result. For Q1 I didn't have BC549 so instead I went with BC547C. I've tried 547B, 550B, 550C and they all did work but there was audible difference in low mid frequency range. It was subtle, but definitely noticeable. I settled with 547C that sounded the best to me. Totally subjective here.
I noticed that two capsules that I bought on aliexpress were very different from each other. Actually I would dare to say that first capsule is almost defective! I have installed it in the first mic and I was annoyed how it produced intermittent noise, sounding as if I was rubbing head grille of the mic. The level was low-ish and a bit dark. But when I closed the mic body noise dissapeared. That's odd since this mic doesn't have problems with shielding since it's not super high impedance. Anyway, I thought that this dark quiet signal is the sound of this mic. But after I populated second pcb and assembled the second mic, that one blew me away. First of all it was louder and brighter. It sounds very different from the sample Rogs posted on his performance page. This one is open without any kind of compression, contrary to Rogs example that sounds a bit like radio DJ's mic processing! And this mic measured 5.4db louder than the first one.
After that I populated new pcb and installed it in the first mic - since I convinced myself that I did something wrong on the first board. But to my surprise it sounds just the same. So it must be due to capsule.
So I guess I'll order more capsules and match two mics since they can easily be tuned to act as a matched pair. But considering how cheap parts and donor body is, I bet I'll even order another body so I can have third mic.
And I'm not saying that my first mic sounds bad - I can see it on some bass cab or some loud sources like amp or drums.
This mic is a real refreshment after spending big bucks building brand name mics and hunting rare or expensive parts for them. Just few weeks ago I built FET847 with chinese capsule and this mic sounds almost as good. I'll have to do a serious test in my studio when I find some spare time to compare them since on my voice they sound very very close!
Big up to Rogs, Khron and all of you guys for this little victory! Humans win!!
Luka
Luka
