RuudNL said:As soon as I have results, I will let you know.
I tried to keep the HF part as far as possible away from the LF stage.
Also there is some grounded copper between the oscillator and the LF emitter followers.
Let's wait and see!
Are there other forum members who are going to experiment with this circuit?
RuudNL said:Great stuff!
I can't wait to experiment with this circuit myself.
(Already ordered the inductors...)
Added is a first PCB layout I am going to use for testing.
RuudNL said:It is the first try, there will be plenty of room for improvement!
First, let's see if and how it works.
I think a PCB has an advantage over stripboard because you have less parasitic capacity.
10 MHz isn't really high frequency. (I have built circuits that worked on hundreds of MHz.)
But...time will tell!
Gerard said:My question concerning any specific requirements for L1/L2 actually referred to the two inductors at the connection to J1, the XLR connector.
Gerard said:Ruud, thanks for posting the Gerber files. I'll see if I can get some boards made here in Ireland.
RuudNL said:Sennheiser used an 8 MHz crystal in their MKHmicrophones....
The 47uH inductors were fitted because that's what I had to hand.....The value is not critical -- anywhere from 47uH to 220uH should do.Gerard said:My question concerning any specific requirements for L1/L2 actually referred to the two inductors at the connection to J1, the XLR connector.
