RuudNL said:
This afternoon I constructed the first test version.
To my surprise everything worked the first time.
Output isn't bad, much higher than a dynamic microphone!
I found the best way to adjust the cores of the coils is with a test tone.
I held the microphone close to one half of a headphone with a 1 KHz tone on it, while measuring the output signal.
Noise isn't a problem. I think a lot of cheap condenser microphones are noisier than this design!
I used a K47 capsule for my tests.
The only problem I have with the design, is the current draw of the oscillator.
The voltage on the pins of the XLR connector is in the order of 22 V, so that would mean a current of ~8 mA.
I have changed some component values in my prototype.
Glad your first build has gone well Ruud..... Certainly good to see a DIY RF biased microphone idea enter the hobby domain - at last!
I have been impressed with how well such a simple circuit performs - I had a feeling that these coils could have a spec that was close enough to be useful for this task!
I think the problem with the fairly high oscillator current is down to the fact that the impedance of the secondary of the Spectrum coils (used as the primary for T1) is a bit too low to be ideal for the task required.
But I found that the addition of R5 (which I note you have changed to 560R) allows for a reasonable balance between voltage and current drawn. R5 also permits the sine wave available at the emitter to be much better quality than trying to drive the emitter with a purely inductive load. At least that's what I've found.
One thing that I've not mentioned in this thread is how this whole concept relies on an unbalanced bridge. If for example the value of C4
exactly matched the capsule value, there may not be enough of a bridge imbalance to allow the rectifier diode to conduct effectively.
Highly unlikely of course - and I've now fitted a BAT85 in place of the 1N4148 to help minimise any such effect.
But it does perhaps point to trying out Baxandall's balanced version - which Gerard mentioned above - as a natural progression of the project.
As you have now confirmed, this circuit works well for a simple project - certainly better than I expected when I first started it!
I'm waiting for some of your PCBs to arrive from JLCPCB - hopefully on Monday next.
I'm getting tired of making stripboard and hand built coil assemblies for my prototypes!
Couple of new observations:
•The addition of the second rectifier to create a balanced output actually reduces the sensitivity slightly, so I shall stick with half wave for the time being. In addition, the extra AC voltage available in that mode might prove to be useful if the bridge does end up closely balanced !
• I have decided to stick with 10MHz for the time being. Although using 12MHz does permit a higher Q tuning, the amplitude is reduced by being further away from the designed frequency of the coils (7MHz), and the sensitivity is slightly reduced as a result.
Maybe one day we shall discover a more suitable IF can?... Trouble is there doesn't seem to be many that have appropriate characteristics, and not have an internal capacitor fitted.
In theory, it's supposed to be possible to remove those caps, but I've never had any luck with that....
