guitarman89
Member
- Joined
- Aug 23, 2017
- Messages
- 10
I have repaired several of these units. You most likely have a bad electrolytic capacitor. I always replace all the electrolytic caps. I also replace all the RC4558 Op Amps in the audio path with Burr Brown OPA2134PA Hi-Fi Op Amps. You have to be careful when de-soldering though. The PCB is low quality and it is very easy to break and/or lift traces. Once I complete the parts replacement I perform a point-to-point check with an ohm meter to verify all connections to the replaced components. These are good units once restored. My only complaint is that they went cheap on the power supply. This results in reduced headroom when using with line level signals. You have to be careful not to overdrive it.
I can provide repair service at a reasonable cost if you are interested
I already replaced the op-amps with 5532s. There is low headroom when used with line level signals. Ill check the caps and continuity near resistors.I have repaired several of these units. You most likely have a bad electrolytic capacitor. I always replace all the electrolytic caps. I also replace all the RC4558 Op Amps in the audio path with Burr Brown OPA2134PA Hi-Fi Op Amps. You have to be careful when de-soldering though. The PCB is low quality and it is very easy to break and/or lift traces. Once I complete the parts replacement I perform a point-to-point check with an ohm meter to verify all connections to the replaced components. These are good units once restored. My only complaint is that they went cheap on the power supply. This results in reduced headroom when using with line level signals. You have to be careful not to overdrive it.
I can provide repair service at a reasonable cost if you are interested.
I have basic supplies multimeter, soldering iron, spare components.
