They are not T03, they are T066. You don't really need heatsinks on these transitors for this box, they don't get hot enough to need them. What I did when using them was use some M3 nuts & bolts through the pcb. Use crinklle washers & put the bolts in from the non component side. Use a couple of nuts on the component side then you can stand the transistors away from the pcb so they get plenty of air around them, bolt them down & solder the 2 legs.I've got one more question about the Zen 2 build how do you mount the TO3's. I've never used TO3's in a build before and just wanted to check how to mount them properly as I cant find any info on mounting to a PCB? There's load of info out there for metal chassis mounting but nothing for PCB's.
I'm assuming as the TO3 case is the collector there is no need to use a insulator underneath them or insulating bushings on the screws?
Hi desol, there's a couple on youtube.Anyone have any sounds samples on drums? Hopefully it's nice and punchy.
