Bowie
- Joined
- Jun 22, 2012
- Messages
- 369
FarisElek said:Starting to realize some of the voltages are off spec on this build. For instance the original schematic says 282v on the 6v6 plates but I'm at 326v. This isn't something I'm hearing. It sounds great. Just something I noticed while rebiasing after a couple weeks of usage. Is this a problem? Some fender amps have their plate voltages as high as 400v.
Thats pretty much the only voltage that is off more than 8v that I've noticed.
Hard to say without comparing the build you have to the original schematic but if it were to follow the original then something may be off somewhere. Check your B+ and see where it deviates. The original schemo is very helpful here as it lists voltages at various points.
The concern is less that the 6V6s are in danger, but more that you may have built something incorrectly. If it were mine I'd want to find out where and why it's going off. It could be an error that affect the performance of the unit and the raised voltage is just a byproduct of it.
