Hi guys,
I hope I'm abiding the rules by posting here...
I've build an Drip La2a and I've been troubleshooting the unit for a while now, but I can't figure out what's wrong. The voltages seem ok. And it sort of passes audio, but way too soft and it does compress (because of the soft signal I think). I've tried to probe the audio and it does not really seem to pass the input transformer well. I got another transformer from Sowter, but this one has the same problem.
The transformer should pass the audio louder than the input signal right? Is there a different way to test the transformer except for checking the resistance and seeing if audio passes? I also thought that the pin 6 should connect to the metal housing, but my meter says there is no connection. Could this be a problem?
Thanks guys! Really, really appreciate it!
