I keep having a constant issue with one of my drip pultec builds. the thing just keeps blowing fuses on startup. As soon as the power switch is engaged, it blows. BUT, and a big but. It doesn't always do it. It all started about 2 months ago, when I walked in my studio and found the thing wouldn't turn on. So I naturally think "well, it must have blow a fuse. It never has before, so it may just be one of those days". I replace it and it's all fine. Then the next day I come in. I flip it on and it blows again. Thinking It could be a bad 6x4, I swap out the rectifier. Still no dice. I try pulling the pre amp tubes and try powering up without those (thinking they may just be trying to pull a ton of current on start up). No Dince. The thing even blows when the rectifier is pulled. So, I start thinking maybe theres a bad cap in it, sometimes you just get sent a crappy cap. But, then i flip it on a few days later to test it one last time. What do you know. The thing runs like a champ for the next month. So curious if anyone has any input on what the issue could be. I'm probably just gonna order a new set of caps and replace them all, so I don't waste more time, cause I'm always slammed. But thought I'd ask here too.
