I just finished my Drip Sta-Level. I powered it up without any tubes installed. The meter light came on but the power lamp did not (which seems strange since I wired them in series to the 6.3VAC "Lamp" terminal on the PCB). I wasn't too concerned about the power lamp so I went ahead and powered off and then installed all the tubes. As soon as I powered back on the fuse in the power receptacle blew.
Any suggestions on what I should look for? The PCB is quite spacious so there's not much chance of any bridged solder points. I'm using the Sowter 9880 power transformer spec'd in the Drip BOM.
https://www.dropbox.com/s/yya7xvwr26oppvg/Gates%209880%20mains%20%28power%29%20transformer.pdf?dl=0
http://vid.firepixie.com/skitch/Sta-Level_Power_transformer_wiring-20150227-133232.jpg
