@Emil - great minds think a like.. Exactly what I have done on the PCB.. there are holes there to connect the upside filter board which can take the LPF rotary switch concentric through the HPF switch as per the 1084. For the high Q switch, it was there in my thoughts but not added to this particular PCB, as it needs a slightly different layout.. of course you can always add a small switch DIY style, but what I probably will do to make things simpler in the long run, is just make two slightly different PCB boards... a 1073(with options of LPF and hi freq switch) / and full 1084 (with high q switch)..
In regards to switching the high shelf "10k/12k/16k/off" on this 1073 board.. yes that option is there a standard.. as per the 1084.
Not 100% sure on costing yet.. still waiting for everything to come in to work out everything.. will let you know...
