martthie_08
I have gotten a little stuck on this Fabio 312 project that I've been working on. Although there is already tons of information out on the 312, I thought it would be nice to have "another" thread, I'm planning to test some different opamps, starting with a diy melcor 1731 guinness: to Volker), then on to Fabio's 25.20 guinness: to Fabio), diy JE-990 guinness: to Volker and Kubi) and there might be interesting things coming up. The preamp board itself has Cinemag CMMI-8 input and Profile 4804 output transformers guinness: to Peter), the line input, servo and unbalanced output options were omitted. The relays are all 12V and I have (been trying to) adapt the psu for this.
Now the first problem: The PSU (Fabio)
I am using a 24V-0-24V mains transfomer which yields about 30V AC no load and 40V DC after rectification. At the moment I have four 2200uF / 35V caps with R1 / R2 = 10R between the two respectively. I didn't pay attention to this initially, but of course the DC voltages are a tad too high for the caps. Can I replace all four caps with 1000uF caps with the idea, that the pos. and neg. rails will be powering only two opamps? I have 1000uF / 63V caps at hand that would fit the pcb perfectly.
Next thing is that I am feeding the input of the 12V relay power regulator (7812 for 12V) the unregulated DC coming off of the R1 / C1 junction with a 470R (5 watter, under the board). This works fine, I checked the output voltage of the regulator (11,76V), but as soon as I start engaging the relays, the voltage drops by approx. 1V per engaged relay. How can I trace this problem down?
Regarding the grounding of the PSU, what is the best way to do this. At the moment, the board is not grounded at all, do all four voltage grounds (+16V / -16V / 12V / 48V) need a seperate path to star ground near the IEC socket? Sorry if this had been discussed before, but I couldn't find anything and I'll promise to make a webpage that will organise this information, so that this stuff doesn't have to be answered every three months :grin:
::::::::::: edit: added some more info's ::::::::::
That's all for now, thank you!
cheers, Marten
cheers, Marten
